4th April 2020, 05:25 | #42 | Link |
In case somebody is looking for a GUI maybe try StaxRip 2.1.0.3 Beta.
https://staxrip.readthedocs.io/intro.html#download
7th April 2020, 13:39 | #43 | Link | |
Artem S. Tashkinov
10th April 2020, 05:45 | #44 | Link | |
This encoder might not be very interesting for everybody but it's often interesting to just take a look at something and play with it, staxrip makes it effortless to try tools, it supports over 190 tools and everything just work, without a GUI some things can be complicated to set up for users like this encoder, vapoursynth, qtgmc etc. It's very transparent what staxrip does because the command lines and scripts can be seen in the app and there is also a very clean log file.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 10th April 2020 at 05:50. |
10th April 2020, 10:24 | #46 | Link | |
https://github.com/staxrip/staxrip/b...ding/AOMEnc.vb
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 10th April 2020 at 10:27. |
10th April 2020, 14:01 | #47 | Link |
Yeah ! It looks like most of the options are already here. If it's not too much trouble re-enabling it, please give it a go. No hurry tho.
Also, new options are available. I haven't checked all and every lines but the most recent options like --tune=vmaf or --enable-fwd-kf are missing. But, well, we can still pass them manually. Thanks in advance. |
19th April 2020, 22:49 | #48 | Link |
Initial version of xAV1vfw v0.82 is released on http://mpxplay.sourceforge.net
The GUI is similar to the other (x264,x265) VFWs (video for windows codec). XAV1vfw uses the svt-av1 encoder library (git 20200419), with several limitations, like - it doesn't work properly under Windows 7 (at me), only under Win10 (wrong CPU detection) - it's very slow, even in the fastest encoding mode (full HD encoding, 4 cores, AVX2, ~5 fps) - AVX512 support is unofficial/experimental, disable it (on the GUI) at encoding problems (crash) - some GUI settings have no svt-av1 support yet (encoder may rejects these), like YUV, Tuning and Profile non-default settings Enabling the Debug log level to Full can display some additional svt-av1 errors and infos. You can follow the updates on my sf.net page https://sourceforge.net/p/mpxplay/discussion/219198 or on my FB page https://www.facebook.com/mpxplay Last edited by MZ/X; 19th April 2020 at 22:51. |
20th April 2020, 02:51 | #49 | Link | |
Angel of Night
Version 0.8.2 released, download at https://github.com/OpenVisualCloud/S...ses/tag/v0.8.2
22nd April 2020, 20:04 | #50 | Link | |
I've wondered about SVT-AV1 having RDOQ, which is something I'm mainly familar with from x265. Is the SVT implementation derived from x265 or the HM? Does libaom have something similar by another name? |
23rd April 2020, 10:51 | #52 | Link |
Angel of Night
I'm not exactly sure what the implementation's provenance is, although it started out almost the same as the aomenc version, but in aomenc and the older versions of SVT it goes by trellis, and was renamed in SVT in 0.8.0 to match up with SVT-HEVC and current industry norms. In libaom, it's on by default up to encmode 5, and manually turned on/off by --disable-trellis-quant.
24th April 2020, 22:24 | #53 | Link | |
Angel of Night
Version 0.8.3 released, download at https://github.com/OpenVisualCloud/S...ses/tag/v0.8.3
27th April 2020, 10:45 | #55 | Link |
Angel of Night
In the current implementation, you have to generate a noise profile, and then feed it in as a second pass. aomenc works the same way. (The implementation is almost 100% identical to aomenc.)
27th April 2020, 12:55 | #56 | Link | |
aom allows you to pass a grain table file, I don't think SVT does. |
29th June 2020, 00:08 | #58 | Link |
Angel of Night
0.8.4 released: https://github.com/OpenVisualCloud/S...ses/tag/v0.8.4
Bug fixes Improve CI Improve Unit Test Coverage Address C vs asm mismatches Fix static analysis warnings / errors Add address sanitizer Various ffmpeg patch fixes Unfortunately fixing film grain didn't make it in, that's among the priorities for the next release. |
7th September 2020, 09:19 | #59 | Link |
Angel of Night
0.8.5 released: https://github.com/AOMediaCodec/SVT-...ses/tag/v0.8.5
Relicensing notice Change the outbound license from BSD+Patent to the AOM license / patent Encoder Added tpl support to adaptively change lambda and quantization parameters within the frame Added multi staged hme support Quality speed trade-offs tuned to VOD use cases Added first level non-optimized support for 2pass VBR and CRF Added combined cli two pass support with options for stats being written to a memory buffer and a specified file Added non square partitioning optimizations Improved lambda generation Build and Testing Bug fixes Improve CI Improve Unit Test Coverage Address C vs asm mismatches Fix static analysis warnings / errors Add address sanitizer Fix symbol conflicts with libaom and libvpx when staticly lined to ffmpeg Edit: New URL, since the move to AOM is complete. Last edited by foxyshadis; 7th September 2020 at 22:57. |
3rd December 2020, 12:50 | #60 | Link |
Angel of Night
0.8.6 minor release: https://github.com/AOMediaCodec/SVT-...ses/tag/v0.8.6
Encoder Further quality-speed tradeoffs tuning for VOD use cases Improved TPL support within 1-pass and 2-pass CRF moode Continued non-optimized support for 2pass VBR and CRF Align kernel nomenclature to prefix svt_aom for kernels brough from libaom to avoid symbol conflicts Build and Testing Bug fixes Improve CI Added CI support for gitlab Improve Unit Test Coverage Address C vs asm mismatches Fix static analysis warnings / errors Add address sanitizer Fix symbol conflicts with libaom and libvpx when staticly linked to ffmpeg |
