Old 14th August 2021, 17:15   #1  |  Link
zweifingerjoe
imdb2mkvtags: a command line tool that generates matroska tags from imdb links
I made a little command line tool that scrapes data from imdb and writes it as matroska tags.
If you want the tags for a specific movie, just pass its imdb title url to the tool. Here is an example for "Star Wars Episode IV":
imdb2mkvtags -o foo.xml https://www.imdb.com/title/tt0076759/
This will save the tags to foo.xml which can then be muxed into a matroska file with mkvtoolnix.
If you also want the full credits with all actors and characters in your tag file, not just what's on the title page, use this:
imdb2mkvtags -o foo.xml -opts fullcredits=1 https://www.imdb.com/title/tt0076759/
To install imdb2mkvtags, install go first, then execute the following statement on the command line:
go get github.com/jwdev42/imdb2mkvtags/bin/imdb2mkvtags
You may also checkout the project's github page, it contains a manual as html file inside the docs folder.
Please notice that the generated xml files will have unix line breaks.
zweifingerjoe is offline   Reply With Quote
Old 18th April 2022, 15:39   #2  |  Link
zweifingerjoe
Release 0.2.1
Version 0.2.1 has just been released.
https://github.com/jwdev42/imdb2mkvt...ses/tag/v0.2.1
imdb, matroska, mkv, tags
