Old 2nd January 2012, 11:02   #1  |  Link
vampiredom
BaseConvert.avsi | Encode/decode binary, octal, hex, Base16, Base32, Base64
I wrote this as an exercise/experiment to try to duplicate some functions from Perl and other scripting languages by using Gscript. I hope others find this useful also.
It allows you to convert integers to arbitrary bases (and vice versa) using "extended" hex notation as needed (up to Base-64). It also allows encoding/decoding of MIME Base64 and RFC 4648 Base32 strings.
You can also encode/decode Base16 (hex) 4-bit text strings.
Download here
# BaseConvert.avsi
# 2012/01/03 -> Some code cleanup
# 2012/01/02 -> Added Base16
#            -> Documentation corrections
# 2012/01/02 -> First Release
# Requires Gscript.dll
# String Functions
# Ord(string c)
# -> Returns the ASCII value of a character as an integer
# encode_base64(string s, string "eol")
# -> Encodes a string to MIME Base64
# -> By default, lines are limited to 76 chars. Set eol="" to disable this.
# decode_base64(string s)
# -> Decodes a MIME Base64 string
# encode_base32(string s)
# -> Encodes an RFC 4648 Base32 string
# decode_base32(string s)
# -> Decodes an RFC 4648 Base32 string
# encode_base16(string s)
# -> Encodes a hexadecimal string
# decode_base16(string s)
# -> Decodes a hexadecimal string
# Integer Functions
# DecimalToBase(int n, int b, int "MinLen")
# -> Converts a base-10 integer (n) to an arbitrary base (b) with optional padding (MinLen)
# -> The result is a numeric or alphanumeric string
# -> Example #1:Convert 255 to octal (377)
#    DecimalToBase(255, 8)
# -> Example #2:Convert 65535 to hexadecimal, 8 digits (00FFFF)
#    DecimalToBase(65535, 16, 8)
# -> Example #3:Convert 16 to binary(10000)
#    DecimalToBase(16, 2)
# BaseToDecimal(string s, base b)
# -> Convert a base number string to its base-10 value, returns integer
# -> Example #1: convert binary 10000 to decimal (16)
#    BaseToDecimal("10000", 2)
# -> Example #2:Convert hexadecimal FFFF to decimal 65535
#    DecimalToBase("FFFF", 16)
# -> Example #3: convert octal 377 to decimal (255)
#    BaseToDecimal("377", 8)
# Notes:
# DecimalToBase and BaseToDecimal use a [0-9,A-Z,a-z] alphabet
# encode_base32 and decode_base32 uses [A-Z,2-7]
# encode_base64 and decode_base64 uses [A-Z,a-z,0-9,+,/]
# Different chars can be specified for values 62 and 63 by setting the global variables
# __base_char62__ and __base_char63__ to any single-character strings (such as "-" and "_", for example)
vampiredom is offline   Reply With Quote
Old 2nd January 2012, 21:59   #2  |  Link
tin3tin
tin3tin's Avatar
@ vampiredom - Please consider to collecting all your great scripts somewhere, so they do not just disappear some day among old threads.
DVD slideshow GUI(Freeware).
tin3tin is offline   Reply With Quote
Old 2nd January 2012, 23:56   #3  |  Link
vampiredom
Aw, thanks! I will, I will ... eventually.
Old 3rd January 2012, 19:34   #4  |  Link
vampiredom
I just posted a new version. Not really any functional changes, just some cleanup. If there is any other character encoding scheme you feel should be added, let me know.
base, decode, encode, gscript, strings
