Old 17th October 2010, 20:37   #1  |  Link
Fozziedd2
Sync
I have been able to duplicate numerous BR disks without issue, but as of late, I have had a sound sync issue. The soud is delayed some 5-7 seconds on many disks. I found keeping the entire disk (languages, previews, etc) helps some, but others are way off. What can I alter?
Here's an INF:
Status]
LABEL=RED_CLIFF_INT_PART_1
VERSION=v0.34.11 (beta)
SOURCE_SIZE=48001564169
SOURCE_VIDEO_SIZE=47465668608
TARGET_SIZE=24589107200
REDUCTION=.506749664428955
RESIZE_1080=0
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=1
ENCODE_STEP=0
COMPLETED=13
REBUILD_COMPLETE=1
[00508]
AUDIO=1
PGS=
M2TS_TARGET=108292711
NSIZE=98666496
FLINK=0
MLINK=0
[00522]
AUDIO=1
PGS=
M2TS_TARGET=168893290
NSIZE=134068224
FLINK=0
MLINK=0
[00521]
AUDIO=1
PGS=
M2TS_TARGET=217930442
NSIZE=168173568
FLINK=0
MLINK=0
[00523]
AUDIO=1
PGS=
M2TS_TARGET=241630175
NSIZE=148015104
FLINK=0
MLINK=0
[00520]
AUDIO=1
PGS=
M2TS_TARGET=242996988
NSIZE=258742272
FLINK=0
MLINK=0
[00004]
AUDIO=1
PGS=
M2TS_TARGET=371290631
NSIZE=363147264
FLINK=0
MLINK=0
[00009]
AUDIO=1
PGS=1
M2TS_TARGET=476746976
RATE=2341
NSIZE=469100544
FLINK=0
MLINK=0
[00005]
AUDIO=1
PGS=1
M2TS_TARGET=623798660
RATE=2345
NSIZE=613883904
FLINK=-1
MLINK=0
[00007]
AUDIO=1
PGS=1
M2TS_TARGET=638404030
RATE=2363
NSIZE=628451328
FLINK=-1
MLINK=0
[00006]
AUDIO=1
PGS=1
M2TS_TARGET=652451255
RATE=2363
NSIZE=642035712
FLINK=-1
MLINK=0
[00008]
AUDIO=1
PGS=1
M2TS_TARGET=680390931
RATE=2364
NSIZE=669487104
FLINK=-1
MLINK=0
[00001]
AUDIO=1
PGS=
M2TS_TARGET=1318624070
NSIZE=1113169920
FLINK=0
MLINK=0
[00000]
AUDIO=1
PGS=101
M2TS_TARGET=18746270199
RATE=15207
NSIZE=18218102784
FLINK=0
MLINK=0
Fozziedd2 is offline   Reply With Quote
Old 17th October 2010, 21:22   #2  |  Link
Sophocles
Try updating to version 35.01 from the link below, and then if you still have an issue run inspect and post the results so that we can be certain of your setup.
http://www.jdobbs.net/freeware/BD-RBV03501.zip
"Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep." Scott Adams
Sophocles is offline   Reply With Quote
sync
