Old 17th December 2009, 15:45   #1  |  Link
EpheMeroN
EphMan
Audio Resampling
How can you resample a 24000Hz audio file to 48000Hz without losing sync with video?
I tried to use SSRC because it's worked in the past when I've done 44100Hz to 48000Hz, but never a resampling like this, and it created out of sync audio/video.
EpheMeroN is offline   Reply With Quote
Old 17th December 2009, 22:53   #2  |  Link
markanini
I recall reading that ssrc was broken for conversions between some samplerates. Try SoX, it's conversion quality is state of the art. Read more here: http://sox.sourceforge.net/SoX/Resampling
markanini is offline   Reply With Quote
Old 17th December 2009, 23:21   #3  |  Link
tebasuna51
tebasuna51's Avatar
Without problems using eac3to (with libSsrc.dll):
eac3to 24KHz.wav 48KHz.wav -resampleTo48000
tebasuna51 is online now   Reply With Quote
Old 20th December 2009, 11:27   #4  |  Link
Midzuki
Unavailable
Midzuki's Avatar
if necessary, add "-down16" to the command-line given above.
24kHz to 48kHz can be a lossless process,
if you have the patience to do it manually
(for example,
mono@24k channel --> stereo@24k.WAV --> pcm.RAW --> mono@48k channel
Midzuki is offline   Reply With Quote
24000hz, 48000hz, sync
