Old 27th January 2009, 23:00   #1  |  Link
wst
Sync issues in FLV to MKV or AVI Remux
Hi all -
I'm trying to remux an FLV I grabbed off C-SPAN with Replay Media Catcher.
I used FLVExtract to get the audio, video, and timecode. I tried muxing to MKV with MKVMergeGUI, giving it A+V+Timecode, but the sync was way off. I also tried bringing the A+V into VirtualDub and setting the framerate to match the audio length, but had a similar sync issue.
The final output can be MOV, AVI, MKV, MP4 - I don't care - just not FLV, because I can't stream it to my TV. If you guys have any ideas, I'd surely appreciate it.
Here's the file:
http://rapidshare.com/files/19036466...0DFE7.flv.html
(about 100MB, FYI)
wst is offline   Reply With Quote
Old 28th January 2009, 17:49   #2  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Try this:
FFmpeg -i myfile.flv -vcodec copy -acodec copy output.mkv
Old 29th January 2009, 21:20   #3  |  Link
wst
Thanks Kurtnoise - that did indeed clear up the sync problem. (Though, not in MPC for some reason).
However, now there are these odd audio artifacts. It sounds like a "cutting out"-type sound - a garbled, high-pitched swoosh of MPEG noise is my best description. Should the audio be reencoded or processed in some way to fix that?
Thanks again,
Will
Old 3rd February 2009, 23:14   #4  |  Link
wst
I tried
FFmpeg -i "myfile.flv" -vcodec copy -acodec libmp3lame -ab 192kbps "output.mkv"
which fixed the audio glitches, but reintroduced the sync problem.
Old 17th June 2011, 12:47   #5  |  Link
lovelove
wst, have you been able to solve the sync problem?
If yes, could you please post the solution? thank you.
lovelove is offline   Reply With Quote
Old 17th June 2011, 19:32   #6  |  Link
wst
Sorry bro, I never figured it out. Maybe try some different settings on libmp3lame, or maybe a new version of ffmpeg...good luck!
flv, mkv, mux, remux, sync
