#121 | Link | |
btw i was the one who hacked the volume bar and the seek slider. my topic on neowin: http://www.neowin.net/forum/topic/93...olumebar-hack/ i even was able to do something like this: (yes, that line is moving with elapsed time.) anyway, here are some help you may need. the status bar is the dialog 10021. the seek bar is the dialog 10022. and if i am not mistaken the dialog 10020 is the controls bar. however you cant do much with these with reshacker except than resizing it. ![]() btw here is my reshacked and hexedited mpc: http://noob.hu/2010/08/19/mpc-hc.png Last edited by xdes; 5th September 2010 at 15:26. |
#122 | Link | |
And the "yuck" referred to that stupid proposal to make the play button green, pause orange and stop red. Yes, the dark design with a bit bigger buttons (I would say 24px is optimal) and possibly with customizable highlight color (but no stupid tricolor please, one color for all) would be nice. |
#124 | Link | |
he could have that gdi stuff before the reshacking process as a blueprint or something like that. ok, sorry. |
#125 | Link |
@bobdynlan - Nice work!
Vote for Doom9's site and forum FAVICON! |
#126 | Link |
MPC-HC Project Manager
Are none of the skinners here interested in the logo and icons contest? http://forum.doom9.org/showthread.php?t=156694
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
#127 | Link |
AutoHotkey MPC-HC control floating bar with popup menus for panscan numpad, audio, subs etc..
script currently under development. screenies: ![]() ![]() slim version: ![]() all functions invoked by 1 left mouse click only ! may be of interest to the MPC-HC community ![]() best in a dual monitor set up |
#130 | Link |
Is this an MPC-HC skin? If it is, where can I find it?
Thanks
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
#132 | Link |
Taste if personal, if bebert wants his player to look like that then he should be able to do it.
bebert, go ahead and post how you did that.
#135 | Link |
Beyond the Corn Border
Download: x86 build vs2008 and x64 build vs2008 and source code I have only tested old rev, but this build is with latest svn. Will test later when I steal some time. Don't laugh at my code, I'm just starting doing stuff like this. And I put quite some work against that *#&$ MFC that does not let you do what you want how you want. Tip: check Tweaks bebert : psychedelic! |
#136 | Link |
I briefly looked over the code, and it doesn't look as bad as you claim it is.
![]() I'll try to run it later.
#137 | Link |
bobdynlan's r2575 mod works great here.
![]() I've gotten used to bigger buttons, so here are a couple of alternative screenshots, using bobdynlan's exe and round black 32x32 toolbar from here. Windowed: ![]() Full screen: ![]() EDIT: By the way, if longinus525 happens to be reading this, any chance you could make a version of your glossy toolbar that looks better with the dark background? The dark buttons are barely visible now. Last edited by Ger; 17th September 2010 at 19:36. |
#138 | Link |
Maybe you guys can get "inspired" by some Winamp skins... if I may suggest (of course, maybe not so tiny but scaled up a bit I think they'd look pretty well):
![]() http://www.winamp.com/skin/cleanamp-v2/146899 ![]() http://www.winamp.com/skin/milk-v1/171470 ![]() http://www.winamp.com/skin/charcoal/163390 ![]() http://www.winamp.com/skin/easy-listening/192687 ![]() http://www.winamp.com/skin/neuramp-blue/147713 ... and these ones mostly for the actual button design ![]() http://www.winamp.com/skin/multipass/142635 ![]() http://www.winamp.com/skin/minima/131340 ![]() http://www.winamp.com/skin/moodlogic-skin/120121 |
#140 | Link |
For those not having the heart to try it out:
This is an almost plug&play mod. I've high-jacked the "Don't use XP-theming..." to enable or disable it at runtime without restart (but some leaks may still be present so don't abuse it). This pnp thing took more than the actual design ![]() Next (main) feature is the seamless gradient background between the toolbar and the seekbar. The toolbar also uses custom glass-like highlight. I would say it's better than default W7 because it aligns the mask to the center of the buttons and it better highlights selected buttons. Also it tries to blend in the separators. Disabled buttons are painted only on the outline. The volume control is redesigned. Ditched the thumb. Has different looks for mute/play and uses the custom colours for selected/not selected areas. Ditched the thumb from the seek bar, too. Useless when you can click anywhere on the channel. An added (or removed in some pov's) functionality, is that it will update media to position only after mouse drag ends. The default behaviour killed my speakers most of the times when used with a touch-pad. And feels choppy with mouse anyway. Some cosmetic changes applied to the status and info bars. Blend in with the toolbar by removing the 3dframe. Will hide most of the white flicker on the right+down sides when window is resized from the left. The playlist has only the background and default text color updated and the borders around reduced. Did not want to mess with sizecbar component. Changed noaudio/mono/stereo images also. Pleasant sound waves should never be drawn as straight lines, better of without them ![]() As Ger pointed out, this mod can be used with your custom toolbar buttons, it will not update those. And this concludes my mod. Please keep mod-related bugs out of main thread, use this one instead. About performance now: I've cared about looks first, and less code added second. Many things could be improved, but don't expect wonders. tetsuo55, nothing can beat performance-wise the 3(three) GDI lines that create the default volume control. Not even dots, as those are even more taxing ![]() I use this one on my ageing crt, helps reduce screen afterglow and does not burn my eyes on popup ![]() |
mpc-hc |
