Old 18th June 2021, 01:45   #19141  |  Link
frencher
French Love
Hi all,
I search my future CPU for Ribot264 for 4K h265 @60fps.
AMD Ryzen, Intel i7/i9 ?
My actual CPU is Intel i7 3930k 6/12 threads (2011) recode at 3/4 fps.
My dream is 15/20 or better fps.
i7 3930k vs Last intel i9
https://cpu.userbenchmark.com/Compar...30K/4110vs1487
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline   Reply With Quote
Old 18th June 2021, 04:09   #19142  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Originally Posted by frencher View Post
Hi all,
I have an overclocked 3930K, they were pretty good, back in the day, but these day's, pretty slow for this sort of "work".
I also have a slightly overclocked Ryzen 9 3950X, and it's pretty damn good !!
I would strongly suggest a Ryzen 9 5900X (or higher).
Of course a Threadripper 32 or 64 core would just smoke this stuff, but at what cost
Check this :-
https://www.tomshardware.com/feature...-ryzen-9-5900x
Not poorly done, just doin' it my way !!!
So much to do, and so little time :(
Pauly Dunne is offline   Reply With Quote
Old 18th June 2021, 04:16   #19143  |  Link
Pauly Dunne
Grumpy Old Man.
Hey Ripmann,
Today is your lucky day, Atak has released another autoupdate, and amongst a couple of other changes (yet tbd), your request has been granted, and you can now freely edit this :-
• In the New Job window, the Output (file path/name) edit field: is it possible to make it editable (same as the Description field above it), so I can just CTRL-V paste the path and name without opening a Save As dialogue?
Old 18th June 2021, 12:14   #19144  |  Link
frencher
French Love
Check this :-
Hello,
How many fps in 4K encoding do you encode with your Ryzen?
Has anyone done the test with a Threadripper 32 or 64?
Old 18th June 2021, 12:27   #19145  |  Link
Pauly Dunne
Grumpy Old Man.
Hello,
Hi, I have to admit I haven't used the Ryzen on any encoding recently, and no 4K for even longer, and it so depends on the settings & filters you use, that can affect things so much, but it's reasonably impressive.
Some 4K encodes can take day's, and it's a bit of an anxious wait, hoping nothing goes wrong, and it's all been a waste of time.
So just re reading your 1st post, you state that your future CPU needs to process 4K x265 @ 60fps....that's a lot...
It would probably be cheaper to have 2 5900X's, (than a Threadripper) and use Distributed Encoding, you'd have 32 cores crunching thru this..
I think I need to rethink how I process 4K footage, unless it needs some sort of denoising or cleanup, it probably doesn't warrant the time it takes to encode them, if it's not really necessary.
If you need to remove video, remove or convert audio tracks and unneeded subtitles, there are other substantially quicker ways to achieve that.
There might be some older post's from those who are rich enough to be able to afford a 32 or 64 core Threadripper setup.
Old 18th June 2021, 14:36   #19146  |  Link
frencher
French Love
4K @ 15/20 fps
Here h265 4K to h265 1080p
With Threadreapper
We now move into the world of video encoding, wherein you are at the whims of the encoder itself. As you can see here, the x.265 encoder demands clock speed almost as much as raw core count, with the 3960X and 3970X outperforming our tweaked 3990X.
https://overclock3d.net/reviews/cpu_...nster_review/7
Old 18th June 2021, 17:15   #19147  |  Link
chainring
chainring's Avatar
@ frencher
Do you have a link handy for that x265 benchmark? Searching brings up multiple hits and different tools.
Thanks!
chainring is offline   Reply With Quote
Old 18th June 2021, 18:15   #19148  |  Link
frencher
French Love
Originally Posted by chainring View Post
@ frencher
Thanks!
The benchmark link is just above the screenshot
Ryzen Threadripper PRO 3995WX 64 cores / 128 threads @ 5489 dollars
Look here: https://www.tomshardware.fr/les-ryze...le-marche-diy/
Old 18th June 2021, 19:01   #19149  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
That benchmark does not show full potential of 3990X!
In distributed encoding mode 64 core CPU will be always noticeable faster than OC 32 core. Check my x265 FHD Benchmark. Divide FPS by 4 to get estimated speed for 4k resolution.
https://forum.pclab.pl/topic/1184884...fhd-benchmark/
Old 18th June 2021, 19:02   #19150  |  Link
chainring
chainring's Avatar
I mean the actual benchmark program itself. I looked at the link you posted and I'm either blind or they make it exceedingly difficult to find the benchmark program.
edit: Just realized that may not be your benchmark run. Duh.
Old 18th June 2021, 21:44   #19151  |  Link
frencher
French Love
Atak,
Would you have a screenshot with x265 FHD Benchmark and your processor.
Thank you.
Old 18th June 2021, 21:49   #19152  |  Link
frencher
French Love
http://www.mediafire.com/file/nm5n7x...chmark.7z/file
Old 18th June 2021, 22:52   #19153  |  Link
Atak_Snajpera
Atak,
Thank you.
Old 18th June 2021, 23:21   #19154  |  Link
frencher
French Love
i7 3930k
Intel Core i7-3930K @ 3.2GHz ( 6C / 12T )
y4m [info]: 1920x1080 fps 50/1 i420p8 sar 1:1 unknown frame count
raw [info]: output file: NUL
x265 [info]: HEVC encoder version 2.2+15-a18ab7656c30
x265 [info]: build info [Windows][GCC 6.2.0][64 bit] 8bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
x265 [info]: Main Still Picture profile, Level-4.1 (Main tier)
x265 [info]: Thread pool created using 12 threads
x265 [info]: Slices : 1
x265 [info]: frame threads / pool features : 3 / wpp(17 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 2
x265 [info]: Keyframe min / max / scenecut / bias: 50 / 500 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0
x265 [info]: References / ref-limit cu / depth : 3 / on / on
x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress : CRF-28.0 / 0.60
x265 [info]: tools: rd=3 psy-rd=2.00 rskip signhide tmvp strong-intra-smoothing
x265 [info]: tools: lslices=6 deblock sao
encoded 2500 frames in 202.16s (12.37 fps), 7025.74 kbps, Avg QP:37.21
Results please send to: x264.fhd.benchmark@gmail.com
Old 18th June 2021, 23:25   #19155  |  Link
frencher
French Love
The cubeupload.com capture is blocked by Malwarebyte.
I use https://goopics.net/
Old 19th June 2021, 02:47   #19156  |  Link
Pauly Dunne
Grumpy Old Man.
4K @ 15/20 fps
That screenshot doesn't really prove a thing !!!
You don't mention what settings you're using, or filters, just "h265 4K to h265 1080p", and is that with the 3930K ???
Who knows..and why aren't you using Distributed Encoding ??
Tell me your settings, and I will do a test on my 3950X for you..
Old 19th June 2021, 02:50   #19157  |  Link
Pauly Dunne
Grumpy Old Man.
i7 3930k
We seem to have a bit of a pissing contest going on here...I get it, you both have pretty basic cpu's.
Also, what's the go with that VERY old x265 build ???
"We're" up to 3.5 + 10 !!!!, that could even make a difference !!!
Old 19th June 2021, 06:07   #19158  |  Link
Pauly Dunne
Grumpy Old Man.
RipBot264 v1.26.1
Hey guy's,
So now that Atak has provided us with some recent updates, you still have to run the updates to get to the current version.
So I have started with 1.26.0 from page 1, and then downloaded & installed ALL the available updates, so that you can just start using v1.26.1, straight off.
So anyone interested, it's here for the taking, this is legit, and updated, untouched v1.26.1.
https://www.mediafire.com/file/ox6da...1.26.1.7z/file
However, if you would like to try my very modified v1.26.1, that has the majority of the components that RipBot uses, all running with the latest available versions & builds, not to mention many, many, more filters, for DeHaloing, Denoising, DeBlocking, Deinterlacing, etc. I've been working on this for a few months, and have been using without issue.
So if you want to give that a try, then grab it here :-
https://www.mediafire.com/file/axhu7...l%2529.7z/file
DO NOT forget to read the "instructions" !!!!
And check out the Tools listing to see what you get, and most of the "extra" filters are found under the "Custom Script" drop down.
Old 19th June 2021, 12:46   #19159  |  Link
Atak_Snajpera
Plot twist: newer builds are even slower !!!
Old 19th June 2021, 12:52   #19160  |  Link
Ryushin
Memory Problem Since Latest Update
Hi Atak,
I've been having a memory error from x265 since the latest update:
x265_x64.exe - Application Error
The instruction at 0x00007FF701D6E902 referenced memory at 0x0000000000020000. The memory could not be written.
Click on OK to terminate the program
Same VM system that has been running for years with ECC memory. Did not install any windows updates in the last week or so. Only the RB update has occurred, but I'm not sure if it was this last update, or the update before that.
Ryushin is offline   Reply With Quote
