Old 26th November 2024, 15:23   #181  |  Link
Kurt.noise
Originally Posted by zezinho View Post
Microsoft antivirus found virus inside the update file!
you're smell like a bot to me...any proof of that ?
you think I'm playing to include some viruses or something like that in there ? *sigh*
it's due to the versioning number of course the sources are freely available idiot.
Kurt.noise is offline   Reply With Quote
Old 26th November 2024, 15:37   #182  |  Link
zezinho
Virus Detected.
I'm not saying that you put the virus in, I'm just saying that Microsoft's antivirus detected it.
It could be that the antivirus interprets some file as a virus.
zezinho is offline   Reply With Quote
Old 26th November 2024, 19:58   #183  |  Link
kalehrl
Well, in my case there was no such detection.
kalehrl is offline   Reply With Quote
Old 27th November 2024, 08:21   #184  |  Link
Kurt.noise
Maybe its related to the latest 7-zip vunerabilities found out since I'm using that to create packages.
Old 27th November 2024, 10:16   #185  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Are those update issues fixed?
VoodooFX is offline   Reply With Quote
Old 27th November 2024, 12:09   #186  |  Link
Kurt.noise
yes, it's better now
Old 27th November 2024, 14:13   #187  |  Link
On VirusTotal (64bit MeGUI) 1/68 (AliCloud) detected as malware:- https://www.virustotal.com/gui/file/...3be588fd09f085
On VirusTotal (32bit MeGUI) 2/66 (AliCloud/MaxSecure) detected as malware:- https://www.virustotal.com/gui/file/...d1cb5cb9a0f28c
So at least 64 out of 66 AV's all thought things are tickety-boo (OK).
[EDIT: Microsoft AV did not detect on either bittage zip]
Nothing to worry about.
Thanks for the new upload Kurt.
EDIT: I once had a detect on a Visual Basic program which I wrote, where there was a 7x7 grid of GUI buttons
for 47 balls (old UK Lottery balls format), and had bad detect on those, I just changed the draw ordering of the balls
and no more detect. Anti-Malware 'guesses' are far from perfect.
[EDIT: I believe that the array of buttons with slightly changing coords were being perceived as some kind of software mutation device, ie self changing code, and that spooked an AV detector]
For a broader picture than your single AV provides, you can upload suspect files to VirusTotal here:- https://www.virustotal.com/gui/home/upload
Old 12th December 2024, 14:59   #188  |  Link
javieracdc
Hi
I'm trying to encode with MeGUI a MOV file to Blu ray compliant, but I got this issue:
--[Information] [12-12-2024 10:58:10] Job command line: "C:\Users\Javier\Downloads\MeGUI_x64-6.6.6.6_20241125\tools\x264\x264.exe" --level 4.1 --bluray-compat --preset veryfast --pass 1 --bitrate 32600 --stats "C:\Users\Javier\Desktop\test\3yuwn0yq.h3y\C241211_00115_Video.stats" --keyint 60 --open-gop --slices 4 --vbv-bufsize 30000 --vbv-maxrate 40000 --colorprim bt709 --transfer bt709 --colormatrix bt709 --sar 1:1 --tcfile-in "C:\Users\Javier\Desktop\test\3yuwn0yq.h3y\C241211_00115.mkv.timestamps.txt.x264" --frames 1825 --output NUL "C:\Users\Javier\Desktop\test\3yuwn0yq.h3y\C241211_00115.mkv.avs"
--[Information] [12-12-2024 10:58:10] Process started
--[Information] [12-12-2024 10:58:10] Standard output stream
--[Error] [12-12-2024 10:58:10] Standard error stream
---[Information] [12-12-2024 10:58:13] avs [info]: 1920x1080p 1:1 @ 60/1 fps (cfr)
---[Error] [12-12-2024 10:58:13] timecode [error]: invalid input tcfile for frame 1
---[Error] [12-12-2024 10:58:13] x264 [error]: timecode input failed
--[Error] [12-12-2024 10:58:13] Process exits with error: 0xFFFFFFFF (-1)
--[Information] [12-12-2024 10:58:13] Job completed
javieracdc is offline   Reply With Quote
Old 12th December 2024, 17:10   #189  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
MeGUI can not do anything about it, 1920x1080@60fps is not BD-legal.
You got to take care of your script that it delivers BD-legal framerates.
Mediainfo of source would help.
Old 12th December 2024, 17:16   #190  |  Link
Kurt.noise
what does this file "C:\Users\Javier\Desktop\test\3yuwn0yq.h3y\C241211_00115.mkv.timestamps.txt.x264" looks like ? (open it in any text editor)
Old 12th December 2024, 20:33   #191  |  Link
javieracdc
These appears:
# timecode format v2
0
0
17
33
50
67
83
100
117
133
150
167
183
200
217
233
250
267
283
300
317
333
350
367
383
400
417
433
and so on
and this is the medianfo:
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@Main
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Duration : 30 s 453 ms
Source duration : 30 s 470 ms
Bit rate : 32.6 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 60.000 FPS
Minimum frame rate : 59.465 FPS
Maximum frame rate : 12 000.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.262
Stream size : 118 MiB (95%)
Source stream size : 118 MiB (95%)
Title : Core Media Video
Encoded date : 2024-12-11 18:25:23 UTC
Tagged date : 2024-12-11 18:25:56 UTC
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : hvcC
Old 13th December 2024, 02:12   #192  |  Link
The double 0 at beginning of timecodes looks a bit suspect to me. (but what do I know )
I would delete one of them and retry.
However, what Emulgator said would still apply.
Old 13th December 2024, 13:35   #193  |  Link
javieracdc
But MeGUi should reencode the video to compliant Blu ray, no? this is the reason
Old 14th December 2024, 06:30   #194  |  Link
Kurt.noise
your issue here seems to be that your input is vfr, not the fact to transcode it to be BD compliant.
Could you share the file somewhere ? I'll see what can I do.
Old 14th December 2024, 18:35   #195  |  Link
Emulgator
Emulgator's Avatar
VFR from 59.465 to 12 000.000 fps... well.
Could be from a mobile phone ?
Old 17th December 2024, 20:58   #196  |  Link
javieracdc
I just record a video with Iphone with variable frame rate
https://we.tl/t-UqtkUzspAR
Old 17th December 2024, 22:05   #197  |  Link
Emulgator
Emulgator's Avatar
I was almost betting on a recent Apple iphone.
To reencode that source for BD I would just Assumefps("ntsc_double") and stretch Audio a bit by 1.001,
1280x720x59.94p would be BD-legal
To reencode that source for UHD-BD I would just Assumefps(60.0)
1980x1080x60p would be UHD-BD legal, 3840x2160x60p would be UHD-BD legal
Old 18th December 2024, 01:45   #198  |  Link
javieracdc
and how convert to 1980x1080x60p that video for UHD compliant
Old 18th December 2024, 12:07   #199  |  Link
Emulgator
Emulgator's Avatar
The x265 target device preset has to be modified. Make your own.
x264 for FHD on UHD-BD: (not your use case with 60p source, but for reference)
If 8bit are desired then AVC, SDR only. No 8 bit HEVC (at least it is not mentioned in Whitepaper) !
If 8bit are desired then FHD only 1920x1080
If 8bit are used, then AVC, SDR only, then FHD 1920x1080 only, and only the 2 following film framerates are possible: 23.976p,24.000p.
(I guess this was meant to accommodate re-using BD assets for UHD-BD Disc Extras)
No 25,29.97,30,50,29.94,60p ! No interlaced !
--level 4.1 --bluray-compat --preset veryslow --tune film --crf 17 --keyint 24 --open-gop --slices 4 --qpmax 48 --ipratio 1.2 --pbratio 1.1 --vbv-bufsize 30000 --vbv-maxrate 40000
x265 for UHD on UHD-BD:
If 10bit are desired then HEVC only, no AVC !
If 10bit are used, then possible: UHD 3840x2160, FHD 1920x1080
If 10bit are used, then possible: SDR (BT.709), SDR (BT.2020), BDMV HDR (BT.2020 / ST 2084)
If 10bit are used, in UHD and FHD the following framerates are possible:23.976p,24.000p,25.000p,50.000p,59.940p,60.000p.
No 30.000p ! No interlaced !
GOP size = Ceil(framerate)
A more recent UHD-BD commandline for x265 can be found somewhere in the x265 threads,
searching and understanding would be on your side.
https://forum.doom9.org/showthread.php?t=183860
Search for posts by benwaggoner, FranceBB, jpsdr, HD MOVIE SOURCE
And this one:
https://forum.doom9.org/showthread.php?t=184077
Old 12th January 2025, 23:24   #200  |  Link
nechto
found errors:
Error1: in x264 config if to choose Tune, Animation, system gets very weird error - it says it can't find file which exists.
Error2: SVT (AV1) codeck not working - causing fatal error
nechto is offline   Reply With Quote
