#481 | Link |
I think the magic number is 8 years, then cannot change thread title any more.
Methinks that title IS changed for 1st post, but not externally to the thread, ie not in forum list of new posts [thread title of new post]. Good advice [which I have to remember to do myself].
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 10th April 2022 at 10:55. |
#482 | Link | |
Edit: Can confirm the filename bug with attachements are fixed, thanks.
(i have a tendency to drunk post) Last edited by mastrboy; 15th April 2022 at 08:49. |
#483 | Link |
Hello all,
I did this in the past but I can't remember how. I want to extract the tracks in a folder named after the original mkv file, I thought you just had to add "{FilenameNoExt}\" in "Options", but it doesn't work. Thank you. |
#484 | Link |
gMKVExtractGUI author
Hi @winoni71,
it was never the intention to add folder in the settings of the filename. Perhaps it was working unexpectedly before, I added a fix to remove invalid filename characters because it created issues, so I don't think it's possible to extract to separate folders via this technique.
#485 | Link | |
madVR options explained |
#486 | Link | |
The only solution I can think of, is to add a dedicated placeholder, like {folder_separator} in the options, in order for the user to explicitly express the wanted intentions, but I'll need to investigate. |
#487 | Link | |
Thanks anyway for your tool. |
#491 | Link |
Hello, been using this for years and its great. Seems I missed many updates since the version I had. However kind of a small thing but would it be possible to have an option to overwrite or skip files if its already made. Mostly just looking for the fonts where I extract a series with many of the same fonts.
#492 | Link |
I want to report extract audio, my autio track 3 in this file when extract name is xxx_DELAY 986000ms when i check info it's only delay 16 s 970 ms.
Example: https://drive.google.com/file/d/10J2...ew?usp=sharing |
#493 | Link | |
I will upload a new version shortly
#494 | Link |
Hey guys!
Thank to @kedautinh12's feedback, I just released a minor version to address the issue with calculating big delays from mkvinfo not working correctly. As always, enjoy! ![]() Download link: https://sourceforge.net/projects/gmk....3.7z/download Changelog v2.6.3
#495 | Link |
Also, one kind request for our administrators, could you please remove the version from the thread title since I can not edit the first post title anymore?
Thank you in advance!
#497 | Link | |
MKVToolNix author
I simply started a new thread & asked the mods to close the old one.
Latest MKVToolNix is v97.0 If I ever ask you to upload something, please use my file server. |
#498 | Link |
Yes I had this issue again last time I posted a new version, the mods changed the title then, but I guess removing the version from the title is a nice workaround, inorder not to have to create a new thread.
#499 | Link |
Long time user of this great tool as well for many years, thanks for creating and maintaining it!
I do have a question: would it be possible to add an option to be able to select a specific subtitle language that is then always selected automatically when opening a video file? Example: when I select Dutch (DUT) as standard subtitle language, opening an .mkv with many subtitles would have DUT selected by default. |
#500 | Link |
Acid fr0g
I have just noticed that if you set
{FilenameNoExt} {Language} {TrackName} and the trackname is empty, it keeps the space after {Language}, leading to a filename .ext format. Would you please fix that?
@turment on Telegram |
| Tags |
| extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui |
| Display Modes | |
