Old 30th April 2013, 07:54   #1  |  Link
pyrobooby
pyrobooby's Avatar
Karaoke Subtitle Encode Problem
Hi, everyone!
I'm working with a karaoke ASS subtitle file with particle effect code(file size: 100MB+).
What I want to do is to hardsub the MV. So I write the following code:
Loadplugin("D:\Program Files\megui_svn\VSFilter.dll")
Directshowsource("E:\mv.mp4")
textsub("E:\mv.ass")
Then I drag the avs script to MeGUI. It takes a pretty long time before the preview window shows up. So does the queue and the encoding(about 10 fps). Pretty slow for my laptop and the video file:
CPU:i5-2450M RAM:8G DDR3 Windows 7 x64 Ultimate 6.1.7601
media info(sorry I don't have an English version):
文件格式 : AVC
文件格式/信息 : Advanced Video Codec
格式简介 : High@L3.1
格式设置, CABAC : yes
格式设置, ReFrames : 1 frame
编码设置ID : avc1
编码设置ID/信息 : Advanced Video Coding
长度 : 3分 32秒
码率 : 2 243 Kbps
最大码率 : 3 749 Kbps
画面宽度 : 1 280像素
画面高度 : 720像素
画面比例 : 16:9
帧率模式 : 恒定
帧率 : 24.000 fps
色彩空间 : YUV
色度抽样 : 4:2:0
位深度 : 8位
扫描方式 : 逐行扫描
bits/(pixel*frame)(数据密度) : 0.101
大小 : 56.7 MiB (92%)
What slows down the speed?
directshowsource, textsub, or both?
I tried to google and it is suggested that use ffmpeg import plugin and assrender for sub.
Any thoughts, Any help?
Thanks in advance!
pyrobooby is offline   Reply With Quote
Old 30th April 2013, 12:19   #2  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
First you should use FFMS2. It's frame accurate and more stable than DSS.
The slow down problem you encountered because of karaoke effect. You could try xy-VSFilter or AssRender to speed up thing a bit. Note that AssRender is a C plugin so you need to use LoadCPlugin(path\to\assrender.dll) to load it.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain
the_weirdo is offline   Reply With Quote
ass, avs synth, megui
