Old 1st November 2011, 11:31   #21  |  Link
kieranrk
Originally Posted by AVC_fan View Post
Hi All,
I am looking for follwoing information:
What can be maximum size of MPEG-2 PES when packatizing H.264? I have old document which mentions maximum size of 64kB. Was there any amendment for H264? Where can I find such documents?
Thanks in advance,
Ajit
You just set PES length to zero to get round that.
kieranrk is offline   Reply With Quote
Old 3rd November 2011, 07:46   #22  |  Link
AVC_fan
Thanks for Reply!
Does this mean, if I set PES size equal to zero I can got with any length of PES?
Lenght of NAL unit can be anything in H.264. So this means if I set PES lenght to zero I can fix NALU greater than 64Kb inside PES of MPEG-2.
DO you have any document to pint in this regard? Please respond.
AVC_fan is offline   Reply With Quote
Old 4th November 2011, 11:50   #23  |  Link
drmpeg
A fairly up to date MPEG-2 systems document can be found here.
http://www.itu.int/rec/T-REC-H.222.0-200002-S/en
PES packet length is discussed in section 2.4.3.7
The AVC amendment can be found here.
http://www.itu.int/rec/T-REC-H.222.0-200403-S!Amd3/en
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
drmpeg is offline   Reply With Quote
