Old 13th April 2004, 23:32   #1  |  Link
wmansir
wmansir's Avatar
DVD ReBuilder: Overview
DVD ReBuilder
Author: JDOBBS
DVD ReBuilder was built to bridge the gap between the incredibly easy but limited "one-click" solutions and the incredibly complex but high-quality methods of DVD ripping and backup.
A major advantage of DVD-RB when compared to older methods is that it doesn't require access to an expensive authoring package. DVD-RB includes its own authoring engine that reconstructs the DVD in a way compatible with its original design.
DVD ReBuilder is currently in beta form and undergoing heavy development by it's author, jdobbs.
Download DVD Rebuilder
This thread will contain the latest release. Subscribe to the thread to get emailed when a new version is released.
DVD ReBuilder: Installation, Setup and Usage
This thread contains information on the basic tools you will need to get started and simple instructions on how to setup and use DVD-RB. There is also a DVD-RB installable version put together by Rockas.
DVD ReBuilder: Settings
This thread contains a short explanation for all the settings in DVD-RB.
Add-Ons
  • Ecl Optimiser by mayhem2408
    Ecl Optimiser allows the user to adjust the bitrate on a per VTS level and make other optimizations. It also gives a convenient display of the bitrates on a per Cell level.
  • RB-Opt by robot1
    RB-Opt allows the user to adjust the bitrate on a per VTS or per Cell level. Includes Script and CCE settings editing.
  • RB Farm by quantum
    RB Farm allows the user to distribute the encoding work over several PCs connected to a network.
  • RB-Keeper by Amenophis
    RB-Keeper allows the user to keep parts of the original video from the DVD and only re-encode other cells. Also includes script editor.
  • ECL Tweaker by quantum
    Allows the user to apply the CCE's internal image filters. Other ECL tweaks are planned.
  • RBLoader by Nic
    Allows DVD-RB to read encrypted DVDs directly from your DVD drive.
  • EclPro by robot1
    Like EclCCE it allows ReBuilder to use ProCoder. ProCoder 1.5+ is required, works best with ProCoder 2.0. ProCoder Express is not recommended.
  • DualDVDRB by Rumbah
    Uses mutliple instances of a single-threaded encoder to take full advantage of dual or hyperthreaded processors. See link for encoder and RB version support.
Skins
Skins change the look of DVD ReBuilder. You can download new skins, or make your own.
Comments and Suggestions
Use this thread to give feedback to the author.
Known Issues and Limitations
This thread contains a list of known issues and limitations, some information on the current status of those issues, and links to issue specific discussions. If you encounter a problem check here first.
DVD ReBuilder: FAQ
Frequently Asked Questions about DVD-RB are answered here. The thread contains information on how DVD-RB works, and resolutions to some common problems.
Bug Reports
If you think you have encountered a bug, follow the instructions in this thread and report it.
Here are some guidelines for posting attachments, such as screenshots.
wmansir is offline
