Old 10th January 2016, 11:47   #121  |  Link
thescrapyard
thescrapyard's Avatar
I know DVDRB hasn't been updated in a long time, but a lot of us still use it for DVD backup as nothing else can touch it for quality or the ease of using AviSynth as well
Is it possible to updated DGDecode to the last version which was 1.5.8 (I can then use the SSE version to squeeze a bit more FPS out my system), just installing the newer DLL over the old one results in a DGDecode/DGIndex mismatch error. Copying the matching 1.5.8 of DGInderx.exe to the main DVD-RB install folder does nothing as well. You still get a version mismatch error and have to go back to the included DGDecode 1.4.5 with DVD-RB Pro
I'm assuming that DGIndex is hard coded into DVD-RB Pro as I can't find it anywhere on the system, and copying it to the install folder does nothing
Thanks
thescrapyard is offline   Reply With Quote
Old 10th January 2016, 12:23   #122  |  Link
Groucho2004
The code to produce the d2v file is part of rebuilder.exe. You're stuck with the version that comes with DVD-RB.
I might make a ICL build of that specific dgdecode.dll.
Old 10th January 2016, 13:48   #123  |  Link
thescrapyard
Thanks for you help, maybe a few others would appreciate that as well
