Go Back   Doom9's Forum > Announcements and Chat > Forum / Site Suggestions & Help
Old 11th April 2002, 19:46   #1  |  Link
cofferscuffs
uber-toddler!
cofferscuffs's Avatar
Read this BEFORE you post about any errors
Please note that we will need the following 3 pieces of information in order to process an error report. Also, please make sure that you submit a correct report by verifying that there really is a problem. Ask a friend to download the file or have a look at the guide. If the problem doesn't happen for him/her it is highly likely that the error occurred on your end.
1) the address of the page where the error occurs (for instance: http://www.doom9.org/software2.htm)
2) the address of the broken link/image/etc (for instance: http://www.doom9.org/Soft21/Audio/HeadAC3hepre22.rar)
3) the IP address of the server you're using. If the URL of the broken link is http://www.doom9.org/Soft21/Audio/HeadAC3hepre22.rar then you have to start a command prompt (press the start button, select run, enter cmd (winnt, w2k, winxp) or command (w9x, winme)) and then type "ping www.doom9.org" where you replace the web address with the actual address you're using (for instance if you use http.//humba.doom9.org/ to access my site you would do a "ping humba.doom9.org")
cC.
cofferscuffs is offline
