Old 17th April 2024, 00:06   #1  |  Link
simple_simon
x264 Frame Edge Smearing
Is there any way to combat the frame edge smearing in grainy video as seen here?: https://ibb.co/qg5Hjnd
Even using placebo settings don't seem to help.
x265 doesn't seem to have this issue: https://ibb.co/0cytPNm
simple_simon is offline   Reply With Quote
Old 17th April 2024, 09:33   #2  |  Link
blob2500
I think the comparison would have been more genuine between frames of the same size.
blob2500 is offline   Reply With Quote
Old 17th April 2024, 19:54   #3  |  Link
simple_simon
The 32pixel size difference wouldn't have made any difference. x264 consistently smears the right and left edges of the frame on grainy video regardless of frame size or bitrate.
Old 19th April 2024, 20:36   #4  |  Link
simple_simon
Has anybody else noticed this problem? Is there a solution to prevent it?
Old 19th April 2024, 21:31   #5  |  Link
benwaggoner
Cropping to mod16 (so width and height are both divisible by 16) can help with some edge conditions like this.
Ben Waggoner
My Compression Book
Old 20th April 2024, 04:59   #6  |  Link
simple_simon
You're right, that did help a lot. I guess I had misunderstood something I had read somewhere else that leaving mod16 black bars on the edges would solve the blurriness because that didn't work. But making the total height and width mod16 did. I had to undercrop a little to achieve mod16 because the only other alternatives were to overcrop by too much or have a pretty huge aspect ratio rounding error. There's still some blurriness but not nearly as noticeable as before. I always thought not fully cropping the black borders was the thing that would hurt compression more than it not being mod16.
This seems like a pretty big flaw, I'm surprised it's never been fixed after all these years. I thought one of the benefits of x264 was that the video didn't have to conform to mod16 anymore. Interesting that x265 has seemed to overcome the problem somehow.
I guess now I have to decide whether it's worth it to have to conform to mod16 for x264 or should I just start using x265 instead despite having a much bigger gap in compatibility.
Old 20th April 2024, 14:25   #7  |  Link
blob2500
in fact, for example, I have always used mod 16, and looking through my x264 TV rips, I don't encounter this problem.
For example, in this image it should have been found, but issue isn't there:
(1248 x 672, x264 version r3153 in this case)
Old 24th April 2024, 19:19   #8  |  Link
benwaggoner
Leaving in black bars doesn't hurt anything as long as they are mod16, but they don't help anything either. Note that 1080p actually isn't mod16, but mod 8. So if you want to do letterboxing, a bottom bar should be +/-8 pixels compared to the top bar to make the encoding mod16.
If you can't do mod16 bars, much better to just crop. H.264 has a sophisticated edge mirroring tool that makes non-mod16 cropping work better than non-mod16 letterboxing.
As long as you crop to the active image area, you don't need to worry about mod16 as much. I try to do at least mod8, but have used mod4 fine without issues (minimum luma block size in H.264 is 4x4, but chroma is 8x8).
Oh, the compatibility gap is much, much smaller these days. Even web browsers (other than Firefox) can play a HEVC .mp4 now if there is a system decoder available.
But x264 should work fine, and certainly will work a lot better, if you crop to active image area.
Ben Waggoner
My Compression Book
Old 25th April 2024, 20:35   #9  |  Link
simple_simon
That's what I thought and have been doing mod4 encodes which all look great most of the time. The only issue is that heavily grained sources seem to get the edges of the frame blurred for some reason. It seems to be more noticable on the sides rather than top or bottom and much more noticeable on non-widescreen aspect ratios too for some reason. I haven't been able to find any x264 setting that reduces the blurring either.
It seems the only choices are to denoise and lose the overall look of the source or just live with the blurred edges. The fact that no x264 setting seems to change the blurriness (either making it worse or better) seems weird though. It just seems like a flaw that's been overlooked.
Old 26th April 2024, 23:54   #10  |  Link
benwaggoner
Are you seeing this with or without black borders?
If you try mod8 or mod16, does that improve anything?
And can you share an example screen shot? If only active image area is being encoded and you're seeing the appearing on both sides instead of just the right suggests in may not be a mod issue.
I have seen something like this in old SD sources where the horizontal blanking interval was left in (generally a somewhat rough border between black and image). Cropping 720x to 704x eliminates the problem for the most part (not always with VHS sources), and is best practice. The common 4:3 and 16:9 SAR are defined relative to 704x, not 720x.
Ben Waggoner
My Compression Book
