Old 4th March 2024, 17:16   #1  |  Link
s4ndr0w
UHD to BD-50 Re-encode Menus
Hi!
Recently, I've been converting some UHD Blu-rays to BD-50, and everything is going well when I lock the bitrate at around 45,000 kbps.
The only issue I've encountered is with one particular Blu-ray menu. This menu consists of a slideshow of scenes from the movie as a background for the main menu. That specific menu is encoded at 108,000 kbps, causing it to stutter and freeze on the UHD player because the bitrate is too high. I tried using the hidden option: MIN_M2TS_SIZE, but it doesn't detect that particular file for re-encoding.
My question is, are there any hidden options I could use to force the re-encoding of menus to lower the bitrate to 45,000 kbps?
Is the option UHD_MAXRATE will lock the bitrate to every M2TS files ? Thank you very much for your help.
s4ndr0w is offline   Reply With Quote
Old 4th March 2024, 21:34   #2  |  Link
Lowpro
Originally Posted by s4ndr0w View Post
Hi!
Re-encode the video used for the menu background outside of BD Rebuilder.
Old 5th March 2024, 09:28   #3  |  Link
musiclover
Try adding REENCODE_MENUS=1 to your BDREBUILDER.INI file.
musiclover is offline   Reply With Quote
Old 7th March 2024, 06:48   #4  |  Link
s4ndr0w
Thank you very much, it works perfectly !
Do you know what's the maxrate i should put for BD-50 ? is 45000kbps a little too low ?
