Old 29th February 2024, 20:56   #1  |  Link
Selur
Selur's Avatar
Inno Setup,... need help
I use the following inno setup script: https://pastebin.com/YyibJFk6
Now I want to expand this so that after all the file copying the content of the two files:
{app}\32bit\fonts\local.conf
and
{app}\64bit\fonts\local.conf
which both contain:
<!DOCTYPE fontconfig SYSTEM "fonts.dtd">
<fontconfig>
<dir>APPDATA/HybridFonts</dir>
<cachedir>APPDATA/fontconfig/cache</cachedir>
</fontconfig>
get adjusted to:
<fontconfig>
<dir>APPDATA/fonts</dir>
</fontconfig>
where APPDATA should be the AddDataFolder of the user (i.e. C:\Users\Selur\AppData\Roaming\.hybrid).
From what I read online extending the Code-section by:
function ReplaceString(const Source, Find, Replace: string): string;
var
  PosFind: Integer;
begin
  Result := Source;
  PosFind := Pos(Find, Result);
  while PosFind > 0 do
  begin
    Delete(Result, PosFind, Length(Find));
    Insert(Replace, Result, PosFind);
  end;
end;
function FileReplaceString(const FileName, SearchString, ReplaceString: string):boolean;
var
  MyFile : TStrings;
  MyText : string;
begin
  MyFile := TStringList.Create;
  try
    result := true;
    try
      MyFile.LoadFromFile(FileName);
      MyText := MyFile.Text;
      { Only save if text has been changed. }
      if StringChangeEx(MyText, SearchString, ReplaceString, True) > 0 then
      begin;
        MyFile.Text := MyText;
        MyFile.SaveToFile(FileName);
      end;
    except
      result := false;
    end;
  finally
    MyFile.Free;
  end;
end;
function ReplaceLocalConfStrings: Boolean;
var
  AppDataPath: string;
  LocalConfPath32: string;
  LocalConfPath64: string;
begin
  Result := True;
  // Ersetze %appdata% durch %appdata%/.hybrid
  AppDataPath := ExpandConstant('{userappdata}');
  AppDataPath := ReplaceString(AppDataPath, '\', '\\');
  AppDataPath := ReplaceString(AppDataPath, 'AppData\Roaming', 'AppData\Roaming\\.hybrid');
  // Pfade zu den local.conf-Dateien in den entsprechenden Ordnern
  LocalConfPath32 := ExpandConstant('{app}\32bit\fonts\local.conf');
  LocalConfPath64 := ExpandConstant('{app}\64bit\fonts\local.conf');
  // Ersetze die Zeichenfolgen in den Dateien
  if not FileReplaceString(LocalConfPath32, '<dir>APPDATA/HybridFonts</dir>', '<dir>' + AppDataPath + '\\.hybrid\\HybridFonts</dir>') then
    Result := False;
  if not FileReplaceString(LocalConfPath32, '<cachedir>APPDATA/fontconfig/cache</cachedir>', '<cachedir>' + AppDataPath + '\\.hybrid\\fontconfig\\cache</cachedir>') then
    Result := False;
  if not FileReplaceString(LocalConfPath64, '<dir>APPDATA/fonts</dir>', '<dir>' + AppDataPath + '\\.hybrid\\fonts</dir>') then
    Result := False;
  if not FileReplaceString(LocalConfPath64, '<cachedir>APPDATA/fontconfig/cache</cachedir>', '<cachedir>' + AppDataPath + '\\.hybrid\\fontconfig\\cache</cachedir>') then
    Result := False;
end;
to do what I want, but it doesn't work, after running the installer, the two files are still as they were.
I got no clue how this all works, so any help is appreciated.
Cu Selur
Old 1st March 2024, 01:14   #2  |  Link
clsid
Don't copy and then modify the files.
Just write simple function to output the desired content to a file. See for example SaveStringToFile or SaveStringsToUTF8File functions in Inno help file.
MPC-HC 2.3.0
Old 1st March 2024, 14:45   #3  |  Link
Selur
Selur's Avatar
Couldn't get it working the way I wanted, but I adjusted Hybrid and the files to work as I need.
Cu Selur
