Old 22nd February 2024, 01:13   #1  |  Link
KSSW
How to add a time code to H264
Time code of first frame: 01:00:00:00
  1. General
  2. Complete name : C:\Users\Use\Desktop\00000.264
  3. Format : AVC
  4. Format/Info : Advanced Video Codec
  5. File size : 85.9 MiB
  6. Overall bit rate mode : Constant
  7. Frame rate : 23.976 FPS
  8. Video
  9. Format : AVC
  10. Format/Info : Advanced Video Codec
  11. Format profile : High@L4.1
  12. Format settings : CABAC / 4 Ref Frames
  13. Format settings, CABAC : Yes
  14. Format settings, Reference frames : 4 frames
  15. Format settings, Slice count : 4 slices per frame
  16. Bit rate mode : Constant
  17. Bit rate : 18.0 Mb/s
  18. Width : 1 920 pixels
  19. Height : 1 080 pixels
  20. Display aspect ratio : 16:9
  21. Frame rate : 23.976 (24000/1001) FPS
  22. Color space : YUV
  23. Chroma subsampling : 4:2:0
  24. Bit depth : 8 bits
  25. Scan type : Progressive
  26. Bits/(Pixel*Frame) : 0.362
  27. Time code of first frame : 01:00:00:00
I don't know how to add a time code?
KSSW is offline   Reply With Quote
Old 22nd February 2024, 12:08   #2  |  Link
Selur
Selur's Avatar
https://stackoverflow.com/questions/...ide-video-file might help
Old 23rd February 2024, 02:12   #3  |  Link
KSSW
If you follow this method, there will be no Time code of first frame: 01:00:00:00
Instead, there will be the following:
Old 23rd February 2024, 15:15   #4  |  Link
Selur
Selur's Avatar
Ah okay, so set simply changes the first time code not set this info.
What do you get if you call:
ffmpeg -i "path to inpu" -f ffmetadata in.txt
in the ffmetadata.txt if you call it on one of the files with this info?
If it includes the info you can probably use '-metadata' option in ffmpeg to set the info.
I only have this info on Quicktime Time code streams not on the raw video,...
Other
Type                                     : Time code
Format                                   : QuickTime TC
Duration                                 : 160 ms
Frame rate                               : 25.000 FPS
Time code of last frame                  : 01:00:00:03
Time code, stripped                      : Yes
Language                                 : English
Encoded date                             : 2016-01-18 21:44:55 UTC
Tagged date                              : 2016-01-18 21:44:55 UTC
Cu Selur
Old 23rd February 2024, 15:30   #5  |  Link
Selur
Selur's Avatar
I tried:
ffmpeg -y -i "g:\TestClips&Co\files\5000frames.mp4"  -timecode 01:02:03.04 -c copy g:\Output\test.mkv
and got:
General
Unique ID                                : 53443209611799196111184538750715928172 (0x2834C9AB657FEA584932404B99939E6C)
Complete name                            : g:\Output\test.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 799 KiB
Duration                                 : 3 min 20 s
Overall bit rate                         : 32.7 kb/s
Writing application                      : Lavf60.20.100
Writing library                          : Lavf60.20.100
ErrorDetectionType                       : Per level 1
Time code of first frame                 : 01:02:03.04
Time code source                         : Matroska tags
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L4.1@Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 32.1 kb/s
Width                                    : 640 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 4:3
Frame rate mode                          : Constant
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.004
Stream size                              : 784 KiB (98%)
Writing library                          : x265 2.6+22-ff02513b92c0:[Windows][GCC 7.2.0][64 bit] 10bit
Encoding settings                        : cpuid=1173503 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=640x480 / interlace=0 / total-frames=0 / level-idc=41 / high-tier=0 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=25 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=0 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-1:-1 / sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.50 / psy-rdoq=10.00 / no-rd-refine / no-lossless / cbqpoffs=-2 / crqpoffs=-2 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=20000 / vbv-bufsize=20000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=0.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=8 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=5 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / analysis-save=(null) / analysis-load=(null) / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Matrix coefficients                      : BT.470 System B/G
VENDOR_ID                                : [0][0][0][0]
video stream didn't chante to vfr, this might not be caused by the '-timecode ....' settings, but by something else.
Old 24th February 2024, 07:43   #6  |  Link
KSSW
Other
Type                                     : Time code
Duration                                 : 160 ms
Language                                 : English
Cu Selur
Hello Selur
Thank you for your the previous answer
So how does below H264 RAW file generate the time code (Time code of first frame : 01:00:00:00) parameter?
This is the H264 RAW file
https://drive.google.com/file/d/1DH_...usp=drive_link
If want to solve the problem
Container encapsulated time code parameters It is not advisable
But rather, the time code parameters need to be included in the RAW video file This is the main problem
Or perhaps the H264 RAW file of FFmpeg does not support the time code parameter at all (Time code of first frame: 01:00:00:00)
Old 24th February 2024, 08:44   #7  |  Link
rwill
Disclaimer: I have not looked at the example raw h.264 stream.
There can be a time code in the picture timing SEI message in H.264. It can contain hours:minutes:seconds:frames. How you get x264 to write such a timecode to the picture timing SEI I do not know.
Old 24th February 2024, 08:57   #8  |  Link
KSSW
It was deleted just now and now it has been reissued
Old 24th February 2024, 10:31   #9  |  Link
KSSW
Videos downloaded randomly from websites
Old 24th February 2024, 17:34   #10  |  Link
ivanb
Timecode is indeed contained within the pic_struct. Unfortunately, I haven't found a way to write it using x264.
ivanb is offline   Reply With Quote
Old 24th February 2024, 17:46   #11  |  Link
ivanb
Here is what x264 source says about it:
// These clock timestamps are not standardised so we don't set them
// They could be time of origin, capture or alternative ideal display
for( int i = 0; i < num_clock_ts[h->fenc->i_pic_struct]; i++ )
    bs_write1( &q, 0 ); // clock_timestamp_flag
