Go Back   Doom9's Forum > Announcements and Chat > Forum / Site Suggestions & Help
Old 10th January 2024, 19:22   #1  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Bug - "The Server is too busy" but actually it's not
Hi there guys,
every once in a while I'm getting the following message:
vBulletin Message
The server is too busy at the moment. Please try again later.
and the forum stats say:
Currently Active Users: 3465 (9 members and 3456 guests)
which looks absolutely fine given that we peaked at 17k in 2017 without the blink of an eye.
When I went to check the actual server workload here the stats were also pretty normal:
19:04:23 up 26 days, 10:03
load average: 13.50, 25.75, 20.01
Memory:
total 8015288
used 3466960
free 3581488
shared 30580
buff/cache 1313160
available 4548328
Swap:
total 16186360
used 3013412
free 13172948
So... I'm a bit puzzled...
Is it vBulletin being dodgy?
Are the stats not actually right?
Dunno... but I'd like to know if it happened to other people too.
Old 13th January 2024, 16:42   #2  |  Link
Selur
Selur's Avatar
Getting "The server is too busy at the moment. Please try again later. " more and more often the last few days.
Maybe lowering "Cookies and HTTP Header Options -> Session Timeout" might help,... (I suspect the board is running into some mqsql or similar session limitation limits)
may be the session time out then simply was larger ? (lager time-outs => more users)
Old 16th January 2024, 06:17   #3  |  Link
manolito
manolito's Avatar
Starting this morning all these issues have disappeared...
A big THANKS to anyone who reported it and to Swede who was probably the one who fixed it.
Thanks again
manolito
Old 16th January 2024, 21:06   #4  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
It is much smoother now, but then again I've been checking the stats and we've always been in the range of 1800 users connected, down from the 3500 peak of the other days.
Perhaps some of those were not actually users and were DDOS attacks? Dunno. Still, it's much better now, so thank you Swede!
Old 18th January 2024, 08:48   #5  |  Link
manolito
manolito's Avatar
Hi FranceBB,
it looks like my last lost came a little too early. After 1 day of almost normal speed the Doom9 site is very slow again. So far no messages like "The server is too busy at the moment. Please try again later.", but the response time when switching to a different forum is very slow. Something is definitely broken here...
Cheers
manolito
Old 18th January 2024, 11:33   #6  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
To be fair, the reason why it was snappy again when you and I both posted was that we were in the 1800 concurrent users range, however now we're back to 3300-3800 concurrent users range and we're seeing the same "issue" as before.
Those seem however to be legitimate users, so I guess it's just the fact that Doom9 is popular.
Given that the server has been up and running for 34 days straight, perhaps Swede could try the oldest trick in the world: rebooting it. Dunno.
We're currently at 3259 concurrent users and the server usage looks like this:
up 34 days load average: 14.30
Memory
Total: 8015288
Used: 4075088
Free: 1678064
Shared: 52696
Buff/Cache: 2609208
Available: 3940200
Swap
Total: 16186360
Used: 2936800
Free: 13249560
which doesn't look terribly bad, though, so perhaps it's not the server but rather his ISP capping the bandwidth?
Old 18th January 2024, 12:51   #7  |  Link
manolito
manolito's Avatar
You may be correct, but what puzzles me is that the slowdown did not come gradually, it came suddenly which looks a lot like some change in the board software, or the ISP which hosts the board changed something in its server configuration.
Whatever, it does look a bit suspicious to me, I hope it is not a sign of worse things ahead...
Cheers
manolito
Old 19th January 2024, 11:49   #8  |  Link
nevcairiel
A load average of 14 or even 25 in the OP is in fact rather bad.
Right now its at 2 with 1800 users, thats more in the range of sensible. Twice the users should not explode that to 7-10 times as high load, unless there is a weird bottleneck somewhere.
Old 19th January 2024, 15:28   #9  |  Link
Swede
Deputy
Swede's Avatar
Hi guys, sorry for being offline for some days... I haven't done anything in the server that should affect the performance. I've now updated the OS and rebooted. Will keep an eye open.
Swede is offline   Reply With Quote
Old 21st January 2024, 08:35   #10  |  Link
manolito
manolito's Avatar
Hello Swede,
whatever you did, it sure did the trick... (at least for me)
Speed is back to what it was before.
Thanks again...
manolito
Old 21st January 2024, 13:24   #11  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
It might be the oldest trick in the world, but if I learned one thing during all those years is that rebooting always works.
This was one more confirmation of it.
Thanks, Swede.
Old 23rd January 2024, 12:54   #12  |  Link
m0rbidini
Got no errors in the last couple of days! Thanks.
m0rbidini is offline   Reply With Quote
