Old 13th December 2023, 13:41   #1  |  Link
DreckSoft
Tool to find x264 encoding parameters?
I'm trying to add credits to an existing video file. For this to work, the encoding parameters need to match (I don't want to reencode everything).
I can get CABAC / ref-frames from media info but matching thiose is not enough.
Is there any tool that can read or guess the correct parameters from a video file?
DreckSoft is offline   Reply With Quote
Old 13th December 2023, 15:17   #2  |  Link
Selur
Selur's Avatar
a. If your video was encoded with x264 the encoding settings should be available in the headers too (unless someone removed them).
b. you could also use h264_parse on the raw .264 stream to get enough data to create compatible streams with x264 (assuming the stream isn't paff encoded); worked for me in MKVCutter.
Old 13th December 2023, 18:39   #3  |  Link
DreckSoft
Unfortunately that's an old HDTV recording with strange parameters
Main profile, CABAC, 2 ref frames is what I've got.
h264parse from gStreamer? That seems awfully complex software.
Old 13th December 2023, 20:09   #4  |  Link
Selur
Selur's Avatar
No, h264_parse from mpeg4ip, see: https://github.com/timmattison/h264_parse
Old 14th December 2023, 08:35   #5  |  Link
ivanb
You can use VTCLab Media Analyzer (or just `mediainfo --Details=1`) to get SPS/PPS parameters, but then you'll have to figure out how to translate them into x264 options
ivanb is offline   Reply With Quote
Old 15th December 2023, 14:24   #6  |  Link
DreckSoft
No luck so far. The original file seems to use really strange parameters and I can't read anything useful from those programs.
