Old 1st November 2023, 03:08   #1  |  Link
novablue
Switch between 2 clips every x second?
Hello,
i would like to load two clips identical in length, size and so on and show clip1 for 10 seconds then show clip2 for 10 seconds, where clip 2 continuous at the position where clip 1 left off, then play clip 1 again where clip 2 left off and so on. I basically want to swap between the two clips back an fourth in an interval. Is there any way to do this automatically? i looked at plugins like ApplyEvery() \ InterleaveEvery() \ ClipClop() but i can't figure out how to do it.
Much help appreciated.
novablue is offline   Reply With Quote
Old 1st November 2023, 04:22   #2  |  Link
How many frames is 10 seconds ? [whole number please]
Old 1st November 2023, 04:42   #3  |  Link
How does this do ?
SrcClip=BlankClip(Length=200000,Color=$FF0000,Pixel_type="YV12").ShowFrameNumber
AltClip=BlankClip(Length=200000,Color=$0000FF,Pixel_type="YV12").ShowFrameNumber
BLKCNT=10 # 10 seconds { however many frames there are in 10 seconds }
SSS=""" Return ((current_frame / BLKCNT) % 2 == 0) ? Last : AltClip """
ScriptClip(SrcClip,SSS)
EDIT: Changed 'SrcClip' inside SSS to 'Last'.
Old 1st November 2023, 06:10   #4  |  Link
novablue
How does this do ?
Thanks this is exactly what i needed. How come i can not put it into a function?
Function MyFunc(SrcClip, AltClip) {
   SSS=""" Return ((current_frame / BLKCNT) % 2 == 0) ? SrcClip : AltClip """
Old 1st November 2023, 12:17   #5  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Isn't ScriptClip a bit overhead-y?
I think this should work:
function SwapEveryN(clip a, clip b, int n) {
	Interleave(a,b)
	Trim(0, n*2 - 2) + last #
	SelectRangeEvery(n*4, n*4 - 1)
	Trim(n*2 - 1,0)
	Assumefps(n*4 - 1)
	ChangeFPS(n*4, linear = false) # edit: speed-up
	Trim(1, 0)
	SelectEven
	Assumefps(FrameRate(a)).AudioDubEx(a)
wonkey_monkey is offline   Reply With Quote
Old 1st November 2023, 16:10   #6  |  Link
Dont know, you tell me.
(Changed framelength to 50,000, curtail time measurements)
ScriptClip
SrcClip=BlankClip(Length=50000,Color=$FF0000,Pixel_type="YV12").ShowFrameNumber
AltClip=BlankClip(Length=50000,Color=$0000FF,Pixel_type="YV12").ShowFrameNumber
Wonkey
return SwapEveryN(SrcClip,AltClip,BLKCNT)
Function SwapEveryN(clip a, clip b, int n) {
    Interleave(a,b)
    Trim(n*2 - 1,0)
    Assumefps(n*4 - 1)
    ChangeFPS(n*4)
    Trim(1, 0)
    SelectEven
#    Assumefps(FrameRate(a)).AudioDubEx(a) # EDIT: fixed FrameRate and AudioSamples
ScriptClip AvsMeter64
AVSMeter 3.0.9.0 (x64), (c) Groucho2004, 2012-2021
AviSynth+ 3.7.3 (r4017, master, x86_64) (3.7.3.0)
Number of frames:                    50000
Length (hh:mm:ss.ms):         00:34:43.333
Frame width:                           640
Frame height:                          480
Framerate:                          24.000 (24/1)
Colorspace:                           YV12
Audio channels:                          1
Audio bits/sample:                      16
Audio sample rate:                   44100
Audio samples:                    91875000
Frames processed:                   50000 (0 - 49999)
FPS (min | max | average):          221.8 | 398.2 | 374.3
Process memory usage (max):         71 MiB
Thread count:                       13
CPU usage (average):                8.2%
Time (elapsed):                     00:02:13.572
Wonkey AvsMeter64
Length (hh:mm:ss.ms):         00:41:40.000
Frame width:                           640
Frame height:                          480
Framerate:                          20.000 (20/1)
Colorspace:                           YV12
Audio channels:                          1
Audio samples:                   110248898
FPS (min | max | average):          38.35 | 208.2 | 191.0
Process memory usage (max):         68 MiB
Thread count:                       13
Time (elapsed):                     00:04:21.791
EDIT: Your clip length [EDIT: duration] is reading higher for some reason (in avsmeter), 00:34:43.333 vs 00:41:40.000.
EDIT: Your FrameRate is 20.0FPS, mine 24.0. [also, audio samples differ]
EDIT: Frames are identical.
N=Import(".\nb.avs")
M=Import(".\nbwm.avs")
StackHorizontal(N,M)
EDIT: This fixes it.
    Interleave(a,b)
    Trim(n*2 - 1,0)
    Assumefps(n*4 - 1)
    ChangeFPS(n*4)
    Trim(1, 0)
    SelectEven
Old 1st November 2023, 17:59   #7  |  Link
wonkey_monkey
I find the difference in speed very surprising. ChangeFPS seems to be the culprit. I can't understand why it would be so slow.
Edit:
This fixes it. linear = true seems a strange default choice.
Old 1st November 2023, 18:09   #8  |  Link
wonkey_monkey
Now:
ScriptClip:
FPS (min | max | average):           74.66 |  48780 |  44597
SwapEveryN:
FPS (min | max | average):          662.0  | 909091 | 827504
Little difference with a real source filter of course, but Every Little Helps™
Old 1st November 2023, 19:23   #9  |  Link
Very nice
Old 1st November 2023, 21:36   #10  |  Link
Rob105
Wrong thread)
Rob105 is offline   Reply With Quote
Old 1st November 2023, 21:47   #11  |  Link
anton_foy
Then they are not identical sadly. Could a dup detector be of assistance for this?
anton_foy is offline   Reply With Quote
Old 1st November 2023, 22:26   #12  |  Link
poisondeathray
Originally Posted by Rob105 View Post
Actually my frames are so far apart (fast panning) that i am getting real mess merging just 2 frames together.
This is from merging one frame with the next one, you can see the tree stem on the left of the house is so far apart.
24fps panning speed 17.5 a second.
Guess i am out of options here except using something like Topaz Video AI to rebuild the missing frames?
What are you trying to do exactly ? / What is the scenario or background information ?
What does this have to do with switching clips ?, or wrong thread ?
Old 2nd November 2023, 11:24   #13  |  Link
Rob105
Wrong thread yeah, pardon.
Old 5th November 2023, 10:53   #14  |  Link
coolgit
What about loop function?
coolgit is offline   Reply With Quote
avisynth
