Old 18th October 2023, 13:53   #21  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
You can set VD2 to decode to RGB24.
Video -> Decode Format -> Decompression format RGB24
"Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingŲage..."
Old 18th October 2023, 19:14   #22  |  Link
andiandi
I don't know if it's important to know whether the source is actually in RGB32 or RGB24? (I guess not, since x264 and x265 shouldn't take that into account). What's a bit confusing too, is that some Lossless codecs with Vdub2 only support RGB32 even when you set the decode format to RGB24. I don't think it's very important, but just in case.
andiandi is offline   Reply With Quote
Old 19th October 2023, 00:49   #23  |  Link
benwaggoner
RGB32 is just 8-bit with an alpha channel. It is effectively interchangeable with RGB24 if alpha isnít used. If you have a choice, do 24.
Ben Waggoner
My Compression Book
Old 19th October 2023, 09:38   #24  |  Link
nevcairiel
fwiw, 24 is terrible for optimizations, because its not a power of 2. 3 byte alignment doesn't play well with CPUs, so you might see it being slower. Worth testing at least.
Old 19th October 2023, 20:46   #25  |  Link
andiandi
OK, apparently the alpha channel can be present but not really used. I'm not quite sure how to check that. (In any case, the DC and GC were in 24-bit color, and the PS2 and Xbox were in 32-bit, if that can be an indication.)
OK, to be tested then.
Old 23rd October 2023, 21:27   #26  |  Link
benwaggoner
24-bit should never be slower than 32-bit. The gap is more than it materially faster due to byte alignment.
Also, definitely try encoding as RGB 444 8-bit full range; exactly the same as your sources. I think some of the encoding challenge comes from color space conversion rounding away the palletized nature of the sources, reducing the efficiency of lossless and transform skip modes.
Ben Waggoner
My Compression Book
Old 25th October 2023, 16:30   #27  |  Link
andiandi
For the color range according to MediaInfo, it's limited range with x265 Lossless RGB 8-bit (with Vdub2), but it's strange because normally RGB should be full range (?).
Another thing I'm not sure about regarding 4:2:0 lossy encodings (x264 and x265) is whether it's better to feed the encoder with the RGB source or first convert the source to 4:2:0 (I see a slight difference, but nothing significant).
Old 26th October 2023, 23:04   #28  |  Link
benwaggoner
I'm on the road without my workstation the rest of the week, so I can't check the files. I concur limited range would be weird, but wouldn't be stunningly weird for devices of these devices predating HDMI by years.
x264 and x264 don't natively include RGB->YUV conversion or subsampling, although many builds have added those features. As long as an implementation does a good job, it doesn't really matter where it happens. My go to method for "trusted quality and good speed" is zscale in ffmpeg. Other things can be as good or as fast, but I don't know anything actually better.
Ben Waggoner
My Compression Book
Old 27th October 2023, 16:15   #29  |  Link
andiandi
Alright. I looked at the various RGB options with Vdub2 (Compression -> Pixel Format -> Other), and indeed there's only Full Range available for RGB, so, I assume that MediaInfo is mistaken.
OK
Old 2nd November 2023, 17:55   #30  |  Link
benwaggoner
Take a look in the VDub2 histogram in the Levels filter to know for sure. Whether or not VDub2 supports it doesn't matter; full/limited is determined by the range output by your emulator.
Ben Waggoner
My Compression Book
Old 6th November 2023, 18:57   #31  |  Link
andiandi
OK. I always see differences, except when I set it to 0-255 for both input and output (even with YUV sources...), maybe I'm missing something ?
Old 7th November 2023, 01:05   #32  |  Link
benwaggoner
Do you see differences if you set both to 16-235?
The basic test is that output video black areas should be as black (RGB=0) in both cases. If 16-235 at darkest is dark gray instead of black, the source is likely full range.
If you encode limited range as full range, darks, whites, and saturation will be muted. If you encode full range as limited range, shadow detail gets turned into flat black, and bright areas get extra white.
Mathematically, a mismatch is essentially turning contrast too high or too low.
Ben Waggoner
My Compression Book
Old 8th November 2023, 18:00   #33  |  Link
andiandi
Yeah, it's only with both 0-255 that there's no difference, for the others, the contrast changes except for 0-255 (input) -> 16-235 (output), which looks more like gamma correction, for example :
https://mega.nz/file/cihWDR7B#bGnwXt...hHlUR2EPRqAsGI
Normally, I should conclude that the source is full range, but it's the same with all videos I've tested with (even with YUV 4:2:0 videos...).
Old 8th November 2023, 23:01   #34  |  Link
benwaggoner
If MediaInfo says that an elementary stream in a .mp4 is limited range, that is generally quite accurate.
Ben Waggoner
My Compression Book
Old 9th November 2023, 18:43   #35  |  Link
andiandi
Good, with samples converted to YUV 4:4:4 (since Vdub2 allows choosing Limited range and Full range for YUV), there aren't all these differences, and it seems to match MediaInfo.
Old 13th November 2023, 20:57   #36  |  Link
benwaggoner
What exactly is matching?
Ben Waggoner
My Compression Book
Old 14th November 2023, 23:24   #37  |  Link
andiandi
The converted YUV 4.4.4 samples (limited range and full range) matches with the source (a Dreamcast source captured in x264 Lossless RGB by the emulator, Limited Range according to MediaInfo). There is no difference in Full Range either, but since there isn't any in Limited Range too, I assume it's limited range for this tested source (as in MediaInfo).
