Old 29th September 2023, 15:55   #1  |  Link
Vincent Vega
getting ssim and psnr from ffmpeg with NV hw decoder/encoder
i'd like to transcode a video to h264 with NVidia card hardware, and get psnr and ssim metrics in output log, using ffmpeg. what would be the command line? it seems like a most basic task, but i just cant seem to find a way to make it work)
Vincent Vega is offline   Reply With Quote
Old 4th October 2023, 19:00   #2  |  Link
benwaggoner
You should be able to use "--psnr --ssim --csv-log-level 2 --csv foo.csv" in ffmpeg. That'll give you a line per frame listing several flavors of PSNR and SSIM for each.
Ben Waggoner
My Compression Book
