Old 20th September 2023, 10:15   #1  |  Link
Lirk
Virtualdub FFMpeg Input Plugin project was removed from sourceforge.net
It was removed in June 2022:
http://web.archive.org/web/202206101...tplugin/files/
http://web.archive.org/web/201908242...chett/profile/
Also was removed some other projects. Is there archive with all available versions for download?
Lirk is offline   Reply With Quote
Old 20th September 2023, 10:22   #2  |  Link
If that is from VirtualDub2 (rather than original VDub 1.10), then maybe could get any earlier ones from older Vdub2 zips.
Old 20th September 2023, 10:42   #3  |  Link
Lirk
There was versions for VirtualDub 1.10/2.0. It would be better to restore all versions of this and other projects by karlpritchett (dloneranger). Interesting, what was the reason for removing?
Old 20th September 2023, 10:43   #4  |  Link
blob2500
I have the latest version.
It was more up to date (2021) than vdub2 (2020)
From its readme.txt attachment
https://sourceforge.net/projects/vir...eginputplugin/
From raythe0n's origional plugin, modified by tateu, later modified by dloneranger
Requires Virtualdub version 1.10.xx
Last version that works with XP is V1.8.4.2
If virtualdub crashes, try reducing its render buffers to 8
This is found on the options menu -> performance dialog
Set the render pipelinevideo buffering to 8 buffers
V2.0.0.0 [12 Jan 2021]
Updated ffdlls
Added these ffmpeg filters for virtualdub
Bilateral
BwDif
Deband
Deblock
NlMeans
SmartBlur
UnSharp
VagueDenoiser
V1.9.0.8 []
Update ffdlls to 4.3.0
V1.9.0.7 [03 June 2020]
Update ffdlls to 4.2.3
Minor fixes
blob2500 is offline   Reply With Quote
Old 20th September 2023, 10:47   #5  |  Link
This lot is from my current VD2 setup, includes
plugins,
plugins32,
plugins64.
https://www.mediafire.com/file/l1s1x...lugins.7z/file
~ 44MB.
EDIT: Includes VirtualdubFFMpegPlugin_0809.zip.
Also,
fccHandler's page.mht [will open in Edge, but not current FireFox (*.mht support dropped after ESR v52)]
AC3.zip
DShowInputDriver-0.93.zip
FLIC.zip
FLV.zip
matroska.zip
mp4inputdriver.7z
mpeg2.zip
QuickTime.zip
WMV.zip
No real idea what any of them are for ???
EDIT: Above Zips, may or may not be also unzipped into plugins32/plugins64 folders.
They are original sourced zips, in plugins32/ZIP/
EDIT: Some of the plugins seem to be in the wrong plugins directories [I'll correct when they cause me a problem ]
