Old 28th August 2023, 18:27   #1  |  Link
ultradj83
Workflow to add a AAC compatibility track to MKV files
Dears,
I have 361 MKV files organized in a Artist / Title folder tree.
Such files usually have DTS or AC3 or LPCM or AAC audio tracks.
For those who don't have a AAC track, I need to add it to avoid compatibility issues with some players.
I'm in difficult in determining an automatic workflow for these.
Regards
ultradj83 is offline   Reply With Quote
Old 30th August 2023, 14:29   #2  |  Link
Kisa_AG
Hello!
There is something very similar to what you are looking for in MediaInfo CLI help:
Batch Processing Example
If a file C:\video\USA Holiday.mpg contains AC-3 audio, then this may be determined and used in the following C:\conversion.bat called using:
C:\conversion.bat C:\video\USA Holiday.mpg
---conversion.bat--------------------------------------------------
@echo off
: Get the codec
C:\Programs\mediainfo_cli\mediainfo.exe --Inform=Audio;%%Codec%% %1 > C:\value.txt
: Read it
for /f "tokens=*" %%A in ('type C:\miresult.txt') do set myVar=%%A
: Test for AC-3
if ".%myvar%" == ".AC-3" goto :AC3
: non-AC-3 processing follows
ffmpeg.....
goto :exit
:AC3
: AC-3 processing follows
ffmpeg....
:exit
Hope this helps.
Kisa_AG is offline   Reply With Quote
