Old 12th July 2023, 05:23   #1  |  Link
FredThompson
FredThompson's Avatar
how to serve frames from Virtualdub2 to Hybrid in Win 10 x64?
I have not used VirtualDub's frameserver for many years and clearly have forgotten how to do so.
I've run auxsetup to install the handler, run VirualDub2 as a frameserver, make the file stub, start to load it into Hybrid and...there is a reported error that the file doesn't contain any video data.
IIRC, there was a time I'd use VFAPI...and also a simple AviSynth directshowsource call.
How can frames be served from VirtualDub2 reliably?s
Reclusive fart.
Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers
FredThompson is offline   Reply With Quote
Old 12th July 2023, 06:26   #2  |  Link
Any good ?
https://www.virtualdub.org/docs_frameserver.html
And/or Google "Virtualdub as a frameserver"
https://www.google.com/search?q=Virt...+a+frameserver
Old 13th July 2023, 18:34   #3  |  Link
FredThompson
Well, that's a pleasant surprise. I consider you one of the luminary stalwarts here.
auxsetup is made for a 32-bit Windows like Win98. It puts the DLLs in Windows/System.
I tried copying the 4 DLLs into System32 and SysWOW64, registered them, and also added the registry values.
hybrid will open the .vdr file and sees the audio and video IDs but doesn't see any of the data. Something eludes me...
Reclusive fart.
Old 13th July 2023, 21:35   #4  |  Link
Get your tongue out'a my butt
Me2
See here (I aint read it all),
https://forum.doom9.org/showthread.p...54#post1819254
EDIT:
Originally Posted by stax76 View Post
in case somebody interested in frameserving from VD to staxrip:
https://github.com/stax76/staxrip/is...ment-299569068
Above link is 404,
here gets you to Issues/ but the linked one dont exist:- https://github.com/staxrip/staxrip/issues
It also dont seem to be in Discussions/.
EDIT: "https://github.com/stax76" became "https://github.com/staxrip/staxrip/"
EDIT: I found issue #159 [is a Closed Issue]:- https://github.com/staxrip/staxrip/i...ue+is%3Aclosed
But that dont seem to be correct one. [Is called "159#issuecomment-299569068" in the 404 link]
Maybe Stax moved it somewhere or included whatever it was in some other discussion.
Maybe ask Stax76 if he moved related stuff somewhere else.
EDIT: Also, check that you're using build 44282 VD2.
EDIT: Maybe better google links [("frameserver" OR "frameserving") with "virtualdub2" 64 bit]
https://www.google.co.uk/search?q=%2...dub2%22+64+bit
EDIT: From the above google link list, ["staxrip/changelog.md at master"]
FrameServer for VirtualDub2 and VirtualDub 64Bit works with Video. Currently a small issue with Audio not decoding properly (Files are Included)
Old 13th July 2023, 22:59   #5  |  Link
poisondeathray
You probably need to force it to use AVISource("PATH\signpost.vdr") . Other source filters and programs will detect data, but not be able to open it correctly. I'm not a hybrid user, but there should be a way to make a script
Old 13th July 2023, 23:16   #6  |  Link
Also, I've noticed that AviSource seems a little more awkward sometimes and requires
AVISource("PATH\signpost.vdr",Pixel_type="YV12"),
where you might expect it to return YV12 without being told. (and VD2 might be returning RGB).
Old 14th July 2023, 05:50   #7  |  Link
FredThompson
I'm using build 44282. Every so often I get hopeful there's an update and...there isn't.
Here's the back story: I do a lot of web conferences now. Usually, I capture with ActivePresenter because it's free and easy to use. When the capture is done and ActivePresenter's editor is open, I'll copy the raw video an audio files to another location then I close ActivePresenter without making any modifications. mkvmerge is used to put the video into an mkv file. (It's faster than ffmpeg and the resultant file plays nice with more software...maybe it's related to odd frame rate...) The mkv video and wav audio files are leaded into VirtualDub because they sync properly and using the null and smart resize filters are useful and easily set visually. The same is true with the timeline and visual preview to set start and end points of a selection. At that point, it's RGB chroma... I thought about using aviSynth's (old curmudgeons like me use that spelling and the "proper" icon of a hand and plater...) AVISource(), Will give that a try. I started using hybrid years ago when working with both NTSC and PAL DV. It was a convenient way to encode to 4:2:2 x264. It's like any other GUI, it has it's quirks and limits but it's become rather familiar. Besides, have you noticed how almost every other editor that has come out since VirtualDub is really awkward for simple edits on a single stream?
I'd been saving video from VirtualDub with the MagicYUV codec. Now, I'm in conferences a couple of times a week and the overhead of saving files instead of serving frames is just too much.
...and...one of the links in the Google search StainlessS pointed to mentioned...VirtualDub2 has native x264 support. Duh! I'll just encode to 4:2:0 with it...
Reclusive fart.
