Go Back   Doom9's Forum > Announcements and Chat > Forum / Site Suggestions & Help
Old 13th June 2023, 19:06   #1  |  Link
johnmeyer
Getting Logged Out After Each Visit
Starting yesterday (June 12, 2023) I am getting logged out of the forum after each visit. Even if I come back ten minutes later, I have to log in again. This is happening on multiple browsers.
I tried to send an email to the administrators, but that function has been disabled.
Old 13th June 2023, 20:33   #2  |  Link
You are ticking the tick box next to your name on login, yes.
I just tried log out, log in (with ticked box), log out, and re-login without having to enter name, and no problems.
(Maybe you just forgot - us old folk need reminders)
Old 14th June 2023, 09:36   #3  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Are you sure that you don't have something that is blocking the cookies on your side?
I've been logged in on my PC and on my phone for days now and it always shows up correctly as logged in.
I do have your very same problem on another forum, though, but not Doom9.
Old 17th June 2023, 23:29   #4  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
I had the same just recently.
My browser seemed to consider http unsafe and did not allow to store cookies anymore.
As I was changing my doom9 bookmark from http to https my login was kept.
Old 18th June 2023, 01:19   #5  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Ahhhh, that must be it, then!
I've been using the https version for quite some time now, that's why I didn't notice it.
