Old 17th December 2022, 17:15   #1  |  Link
GAP
Which Input Driver is better for Virtualdub2 (Windows XP)?
If my previous posts were any indication, I had some trouble with the "Requested frame not found" when I was convertitng on my Virtualdub2. I wasn't sure what caused this error but I was told that it might have something to do with input driver. I was told this but it wasn't until recently that I discovered it. After discovering the input driver option, I switched the input driver and I was able to convert my video just fine.
From I what I learned from that post
, there are two input drivers for Virtualdub2. There is the "Caching Input Driver" that can read most video containers. The other one is "Audio/Video interleave input driver (internal)" that can only read AVI files. The former "Caching Input Driver" is FFMPEG based and can read most files but I cannot use it to convert the files from AVI to MP4. The latter "Audio/Video interleave input driver (internal)" can read my files and convert AVI files just fine. I mostly use lossless codecs for AVI video captures and I want to convert to MP4 with the x264 codecs.
With all that said, what is better for my computer for seeking and conversion? And on Windows XP no less?
GAP is offline   Reply With Quote
Old 17th December 2022, 17:23   #2  |  Link
kedautinh12
FFmpeg, L-SMASH-Works
Old 17th December 2022, 19:04   #3  |  Link
GAP,
I already gave you an ffmpeg script to batch convert all to AVI,
is way simpler than screwing around with awkward files.
Then can easily load them into VD2 as avi.
Old 18th December 2022, 20:32   #4  |  Link
GAP
Edit: I found the post in question although I do have a question about the output. I will post int that thread.
Old 19th December 2022, 02:07   #5  |  Link
OK, I posted better solution in the other thread:- https://forum.doom9.org/showthread.p...16#post1979916
