Old 15th December 2022, 18:06   #1  |  Link
Willard
Help with setup
Hi!
I've used BD-Rebuilder for several years, with no problems. Unti; recently...
My Win7 PC has a failure of the system drive, which necessitated a replacement drive, and a re-install of Win7, and everything else.
On installing BD-Rebuilder, I just can't get it to work. I've tried all the tips I've found online, and have uninstalled and re-installed several times.
Here is what I get from BD-Rebuilder:
[12/15/22] BD Rebuilder v0.61.28
[10:59:57] Source: TOP_GUN_MAVERICK_00001
- Input BD size: 38.47 GB
- Approximate total content: [02:10:14.515]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Auto Quality: Very Good (Very Fast), 1-Pass VBR
- Decoding/Frame serving: DirectShow
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[10:59:59] PHASE ONE, Encoding
- [10:59:59] Processing: VID_00351 (1 of 1)
- [10:59:59] Extracting A/V streams [VID_00351]
- TSMUXER ERR: 0xFFFFFFFD
- Extracting video streams [VID_00351]
- Bitstream exception std::exception. It does not have to be! Please contact application support team for more information.
- Error in attempt to extract video.
[11:00:06] - Failed to retrieve audio, aborted
I have also tried the Inspect app, trying to determine the problem. Here are the findings from that:
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 4504, not recommended version
- WIN7 preferred AVC CODEC: Not Set correctly
- WIN7 preferred VC-1 CODEC: Not Set correctly
- WIN7 preferred MPEG2 CODEC: Not Set correctly
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- BD-RB vUNKNOWN, not current
According to this, I have some codecs that aren't set correctly, but I'm at a loss - I don't know how to set these.
Any help would be greatly appreciated!
Willard is offline   Reply With Quote
Old 15th December 2022, 18:56   #2  |  Link
musiclover
The inspect app is no longer in use. Try 'Inspect (show settings)' under the help menu.
musiclover is offline   Reply With Quote
Old 15th December 2022, 21:11   #3  |  Link
Willard
Thanks!
Here's what that reveals:
[12/15/22] Checking System Settings
- BD-Rebuilder v0.61.28
- Working Path Free Space: 794.58GB
- LAVFILTERS: Ok
- X264: Ok
- X265: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[12/15/22] Systems Settings Check complete
Now what?
Old 16th December 2022, 09:41   #4  |  Link
musiclover
Have you tried another source to make sure it is not source related?
Old 16th December 2022, 20:27   #5  |  Link
Willard
THAT WAS IT! Thanks, I completely overlooked that!
I think, since I just re-installed the program, that I fixated on the program settings being wrong.
Sometimes, we need someone to point out the obvious thing that we (I) are overlooking.
Thanks again!
