Old 21st November 2022, 10:33   #1  |  Link
color
color's Avatar
Delogo (deblend problem)
LINK TO SHORT VIDEO + BMP I USE:
https://sprend.com/download?C=7c82ee...5cf27ddd9bf894
I use bmp as Analys and DeBlend
I do use "Sample input" as "All frames - slowest, but most accurate".
I do try changing "DeBlend shift" but nothing works. I have looked in gimp and the text is not 100% white and some "data/image" is behind.
Something else I can do with DeLogo to get it better or is it only "Repair" that works? (looks aweful)
Also. I was thinking is it possible to create a image with alpha and only dark/black color and somehow use it in a transparent to darken the logo so its not visible?
Automatic Colorization
color is offline   Reply With Quote
Old 21st November 2022, 10:37   #2  |  Link
kedautinh12
Do you use InpantDelogo??
Old 21st November 2022, 10:49   #3  |  Link
color
color's Avatar
Never heard of InpantDelogo, I use this.
Is it this you mean? https://forum.doom9.org/showthread.php?t=176860
It seems like InpaintDelogo only blur together the edges not deblend?
EDIT: I saw it has some other options as well. I only get "Incorrect Loc". So don't know what I am doing wrong.
Old 21st November 2022, 11:20   #4  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
But in the first sentence it says that it does deblending.
Where you got "only blur together the edges" impression?
Btw, Vdub Delogo is outdated.
VoodooFX is offline   Reply With Quote
Old 21st November 2022, 11:26   #5  |  Link
color
color's Avatar
I looked at this as the bottom: https://forum.doom9.org/showthread.p...54#post1884254
But I saw and updated my post only within 1 minute.
Old 21st November 2022, 11:28   #6  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Probably that's because you didn't set Loc coords, that's crop where logo is (leave 10-20 pxs borders around logo).
And edit your bmp, red pixels to full white.
Old 21st November 2022, 11:57   #7  |  Link
color
color's Avatar
InpaintDelogo(mask="C:\1.bmp", Loc=coords, Mode="Deblend")
does not work
Old 21st November 2022, 12:04   #8  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
does not work
Post your full script.
We are [not] the fortune tellers to know what "does not work" or "coords" means.
Old 21st November 2022, 12:10   #9  |  Link
color
color's Avatar
We are [not] the fortune tellers to know what "does not work" means.
DirectShowSource("C:\video.mkv")
InpaintDelogo( mask="C:\1.bmp", Loc=coords, Mode="Deblend")
"I don't know what 'coords' means"
Old 21st November 2022, 12:52   #10  |  Link
kedautinh12
You need set values with Loc. First, you need use InpaintLoc() to choose coords around Logo. Second use InpaintDelogo() to make Logo and delogo. Examples:
https://github.com/Purfview/InpaintD...logo.avsi#L196
https://forum.doom9.org/showthread.p...03#post1973103
Old 21st November 2022, 13:18   #11  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Coords is short form of coordinates, I meant set coords of your logo to Loc parameter.
For your sample it's:
InpaintDelogo( mask="C:\1.bmp", Loc="1388,944,-280,-24", Mode="Deblend" )
or like this if you want:
coords = "1388,944,-280,-24"
InpaintDelogo( mask="C:\1.bmp", Loc=coords, Mode="Deblend" )
Use Crop(1388,944,-280,-24) to see what those coords means.
Btw, never use "DirectShowSource" filter, it's outdated too.
Old 21st November 2022, 13:53   #12  |  Link
color
color's Avatar
Oh, now I get it, "location" for the logo. I thought it ment it is creating data from the mask. (thanks for having patient with me, my english is not so great)
I do get this error now. Still a bit unshour what is wrong, I have checked so all the required plugins are up to date as well. Or have I missed something?
EDIT: I use latest Avisynt+
Old 21st November 2022, 14:09   #13  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
What is "LSMASHSource2", I've never heard of it?
Try to use normal "LWLibavVideoSource" instead. [Delete the "txt" files created for your mask before doing so]
Old 21st November 2022, 14:19   #14  |  Link
color
color's Avatar
function LSmashSource2(string path, int "atrack",
\          int "fpsnum", int "fpsden",
\          string "format", bool "cache")
    atrack   = Default(atrack, -1)
    fpsnum   = Default(fpsnum, 0)
    fpsden   = Default(fpsden,  1)
    cache    = Default(cache, true)
    format   = Default(format, "")
    video = LWLibavVideoSource(path,
    \               fpsnum=fpsnum, fpsden=fpsden, format=format,
    \               cache=cache)
    return (atrack==-2) ? video: AudioDub(video,
   \    LWLibavAudioSource(path, stream_index=atrack, cache=cache))
I got recommended to use this a while ago instead or DSS2.
Oh, I did delete the txt. But now It says "mask is empty". Am I using wrong color?
Old 21st November 2022, 14:36   #15  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
How anyone can know but only you?
I don't see any colors in your sentences. Probably you are doing there some crazy things...
Old 21st November 2022, 14:40   #16  |  Link
color
color's Avatar
I ment in the bmp. Sorry, my english is not so good so I have some problem understanding.
EDIT: The mask I used red. I did post the image above in the link, but here it is as well.
Old 21st November 2022, 14:44   #17  |  Link
kedautinh12
I think you need use white color with this logo or you can create .bmp mask automatically with automask=1, after you use this mask with automask=0
Ex: https://forum.doom9.org/showthread.p...03#post1973103
Old 21st November 2022, 14:53   #18  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
https://i.ibb.co/k6j76jS/1.png
Now I see that it's still red. I saw your first post, that's why in 6th post I wrote that you need to change red to full white.
Btw, InpaintDelogo has automatic mask creation feature, you can activate it like this:
InpaintDelogo( mask="C:\automask.bmp", Loc="1388,944,-280,-24", Mode="Deblend", Automask=1)
This will only create a basemask [bmp], after you got it remove "Automask" to continue with delogo.
Old 21st November 2022, 15:00   #19  |  Link
color
color's Avatar
Oh, now something did happen! It was white color not red (I thought it was like virtualdub delogo it uses red, but white worked a lot better). I don't get it to work great, I will try creating a automatically mask instead. It seems like it would work better.
Old 21st November 2022, 15:06   #20  |  Link
kedautinh12
You need upload result samples. Mr. VX, author's InpaintDelogo will help you to make results better
avisynth, virtualdub
