Old 17th November 2022, 13:48   #1  |  Link
DanDare1983
Main Movie goes over the 25gb target?
I'm using BDrebuilder to simply compress my movies to main movie (25gb) and have noticed some movies go over this target. I'm using ffdshow as frame server and using crf for quality on the high quality (default) setting. Does anybody have any previous experience in regards to this problem and how to rectify the problem. Thankyou
DanDare1983 is offline   Reply With Quote
Old 18th November 2022, 11:53   #2  |  Link
gonca
Use 2 pass for a fixed size or reduce your target size when it overshoots while using crf.
gonca is offline   Reply With Quote
Old 18th November 2022, 22:37   #3  |  Link
jdobbs
CRF uses an alogorithm to attempt to predict output size, it is pretty accurate, but can sometimes be wrong. If it oversizes, look at the predicted value, and set a fixed CRF that is slightly larger.
Website: www.jdobbs.net
Old 19th November 2022, 12:41   #4  |  Link
DanDare1983
Thankyou for getting back to me. The movie in question was very grainy and them type of movies rarely encode well and can give huge file sizes. I did however try two pass and that got me a file around 21.5gb which was perfect as I don't like maximising the space on the Blu-ray Disc. In regards to the CRF can you manually set that? I'm just using the default high quality atm, could you tell me the crf for high quality. I assume its around the 21/22 mark.
Old 19th November 2022, 13:22   #5  |  Link
gonca
From the HIDDENOPTS file
FIXED_CRF=n n = 1..50 - force CRF encoding to use this CRF value (output size control disappears)
This is entered in your config file after [Options]
Old 19th November 2022, 14:48   #6  |  Link
DanDare1983
Thanyou very much for your help, I'll try this when i get home.
