Old 15th November 2022, 11:41   #1  |  Link
DanDare1983
Seamless Branching Question?
I'm just wondering how the program gets on with films with seamless branching (Directors Cut, Extended Cut). I know when making remux frames have to be dropped to keep everything in sync. Any help would be appreciated.
DanDare1983 is offline   Reply With Quote
Old 15th November 2022, 14:08   #2  |  Link
von Suppé
von Suppé's Avatar
With a polite nod to its creators, I don't know how BD Rebuilder behaves on this matter.
I always use DGDemux. It handles branched videostreams perfectly and also outputs gap-processed audio, including TrueHD+AC3. Importing which mpls dictates what version to process.
Old 18th November 2022, 22:44   #3  |  Link
jdobbs
It should adjust for seamless branching appropriately. Have you had problems with it?
Website: www.jdobbs.net
Old 19th November 2022, 12:47   #4  |  Link
DanDare1983
Yes I've had one problem in regards to seamless branching but that's no fault of bdrebuilder. The actual main movie playlist consists of 5 m2ts files and for some reason there's a 1 second empty video m2ts as the first m2ts causing the video to go out of sync. You know some of these companies have stuff like colour bars and additional m2ts files with no video at all, either poor authoring or just trying to cause problems for people who rip the discs.
Old 20th November 2022, 17:00   #5  |  Link
hubblec4
Matroska find' ich toll
You can easy ignore such short mpls files. Remove it from the chain and all should work.
hubblec4 is offline   Reply With Quote
