Old 7th November 2022, 20:08   #1  |  Link
prince25
Resize movie .m2v 576i widescren
Sorry for my English.
I need to convert my movie .m2v, 720x576, widescren, interlaced, uncompressed file. AVI, or in an mpeg, with aspect ratio 1024x576, interlaced.
I created a .dgi file and made an AviSynth .avs file with the following syntax:
DGSource ("input.dgi")
Spline36Resize (1024,576).
I opened the.avs file in virtualdub.
The output file is an uncompressed AVI. With Media info the scan type is not clearly read: progressive or interlaced.
Can you help me?
Thank you very much.
prince25 is offline   Reply With Quote
Old 13th November 2022, 13:44   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
IIRC, AVI is guessed upon by the playing/decoding device following conventions
like "FourCC dvsd AND 25fps (40000µsecperframe) is assumed to be interlaced AND BFF",
or/and
"resolution 720x576 @4:3 will ask for a PAR of 16/15"...
If you want to keep info about scan type, field order etc:
Choose a container different from AVI.
You might want to use x264 and mux into .mp4, or .mkv, or .MTS or .m2ts
Old 14th November 2022, 10:10   #3  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Are you able to provide a sample of the source?
Old 14th November 2022, 14:47   #4  |  Link
He does not seem to have been back since his first ever post on 7th. (perhaps a bit impatient)
