Old 9th March 2022, 19:36   #1  |  Link
stax76
stax76's Avatar
What is the startup performance of different programming languages?
To answer my own question, I made some performance tests to find out how fast a test app or script can start, print Hello World and terminate.
These are my numbers:
C: 10 ms
C++: 10 ms
Rust: 10 ms
Python: 30 ms
.NET Framework: 30 ms
.NET Core: 40 ms
Lua 5.1: 13 ms
Lua 5.4: 13 ms
PowerShell 5.1: 230 ms
PowerShell 7.2: 400 ms
GO: 15 ms
How it was measured:
using System.Diagnostics;
int count = 0;
Stopwatch w = new Stopwatch();
w.Start();
for (int i = 0; i < 100; i++)
    count++;
    Process p = new Process();
    p.StartInfo.UseShellExecute = false;
    p.StartInfo.FileName = @"D:\Projects\test\test.exe";
    p.Start();
    p.WaitForExit();
    p.Dispose();
w.Stop();
Console.WriteLine(w.ElapsedMilliseconds / count);
Console.ReadKey();
I was surprised by some of these numbers, positive and negative.
Maybe somebody of you find this topic also interesting. Most of the time it's not that important, I admit, but sometimes it can be! That's why I wanted to know exactly. I certainly use some apps I wish would start faster, for instance Anki and JDownloader, and I had a PS script to paste the date that was way too slow. It was launched with Flow Launcher using my Favorites plugin and my run-hidden app to hide the console window.
Old 9th March 2022, 23:27   #2  |  Link
videoh
Useful n00b
Depends on lots of things you are not controlling for, e.g., amount of static data to be zeroed.
Old 11th April 2022, 15:22   #3  |  Link
wswartzendruber
hlg-tools Maintainer
wswartzendruber's Avatar
On Debian 11, Linux will start one of my Rust programs, output the help screen, and exit in 2 ms. I am not writing to the console, but diverting STDOUT to /dev/null. This was a cold start on a fresh boot, so nothing was likely cached in RAM.
wswartzendruber is offline   Reply With Quote
Old 20th November 2022, 12:00   #4  |  Link
metis
metis's Avatar
What about FreePascal (FPC)?
Not so popular, but very powerful and fast, comparable to C++.
FFmpeg based...
- FFPlay4Laz = FFmpeg+SDL+PortAudio = A highly responsive Lightestweight-Mediaplayer with outstanding Sound
- FFGrab4Laz - RunFFmpeg = A One4All-GUI for various FFmpeg-Tasks
metis is offline   Reply With Quote
