Old 3rd February 2022, 21:08   #1  |  Link
alexVS
Opening HEVC 4K HDR 10bit problem
I'm working with Avisynth+, trying do decode HEVC 4K 10 bit video
And want to try to reecode it to usual AVC h264 8bit
But somehow I receive orange grass, green sky. After opening. Strange.
What am I doing wrong?
Maybe this is file for 3d glasses? (green, red) something like that...
My avisynth script is simple:
LoadPlugin("c:\Program Files (x86)\AviSynth+\plugins+\LSMASHSource.dll")
a1="dolby-vision_HEVC_4K_EAC3.mp4"
LWLibavVideoSource(a2, format = "YUV420P10")
ConvertBits(bits=8, dither=1)
converttoYV12()
File: https://disk.yandex.ru/d/njJQBo6mTMEaxg
Screenshot: https://disk.yandex.ru/i/VqX9ETvRPckgXQ
alexVS is offline   Reply With Quote
Old 4th February 2022, 00:36   #2  |  Link
quietvoid
Your file is Dolby Vision profile 5, it uses a special colorspace.
Not sure there's a solution for converting it in AVS, but FFmpeg 5.0 with vf_libplacebo should be able to convert it.
LG C2 OLED | GitHub Projects
quietvoid is offline   Reply With Quote
Old 4th February 2022, 08:48   #3  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Working on it...
Well, I know that the sky is supposed to be blue, but what about the rest? XD
Do you have any official specs about which color scheme is using?
Anyway, this is the first beta attempt
Original:
LinearTransformation():
expect a new beta soon... (after breakfast)
Old 4th February 2022, 10:06   #4  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Ok, I've updated the master, try with:
LinearTransformation(Input="dvhe0509", Output="Linear_BT709")
right after indexing.
We're still far far off from a real implementation, but I can't find any official document on the web...
Reverse engineering everything is hard, especially 'cause I don't have a color palette anywhere in the video... Anyway, so far it produces this on your particular sample:
High res pics here: https://i.imgur.com/mI0qbKs.png - https://i.imgur.com/y20y40f.png - https://i.imgur.com/5ZFcmvU.png
EDIT: Work in progress here too https://code.videolan.org/videolan/l...ests/207/diffs
Old 4th February 2022, 14:36   #5  |  Link
quietvoid
Well until the SMPTE standard drops for IPT PQ c2 (which was teased in the journal), there isn't really an official document.
Apparently Dolby only has code.
Basically you have some form of ICtCp with ST2084 transfer function, with luma being reshaped into pseudo-SDR.
So it requires the metadata/RPU to decode/reshape properly.
Both FFmpeg 5.0 (decoding) and libplacebo/mpv (rendering) support this now.
It could be added to ffms2 for AVS (it's already there for the VapourSynth plugin).
See https://github.com/FFMS/ffms2/commit...f9c021653d50f5
Though that only propagates the metadata.
The original info comes from ETSI GS CCM 001 V1.1.1, which describes the process in pseudocode.
Old 4th February 2022, 18:36   #6  |  Link
Selur
Selur's Avatar
Nice!
Old 5th February 2022, 18:06   #7  |  Link
alexVS
Works great!
Old 5th February 2022, 19:29   #8  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by alexVS View Post
Works great!
Yeah but I'm not totally happy with the result ehehehheh
Do you happen to have colorbars in dvhe0509?
Old 6th February 2022, 10:50   #9  |  Link
Selur
Selur's Avatar
may be those over at https://www.murideo.com/test-pattern-library.html help,... (not sure they have the right version)
Old 15th February 2022, 16:17   #10  |  Link
Balling
This is now supported by mpv, reference with decode to PQ. You cannot reverse it. The spec is public and very complex, but we did it!
Balling is offline   Reply With Quote
Old 15th February 2022, 16:20   #11  |  Link
Balling
Yes, there is. On trac.ffmpeg. but you do not need to waste time on it, mpv implemented it. The hardest part is reshaping and that is done too.
Old 15th February 2022, 18:08   #12  |  Link
Selur
Selur's Avatar
@Balling: I'm happy that mpv can playback dolby vision files, but how does that help with decoding a dolby vision file in Avisynth?
Old 25th February 2022, 21:29   #13  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Just FYI in case anyone is interested, we now have a proper version: https://forum.doom9.org/showthread.p...42#post1964642
Old 26th February 2022, 06:32   #14  |  Link
Selur
Selur's Avatar
Nice! Thanks for the info!
10bits, avisynth, hdr, hevc. h.265
