Old 18th March 2024, 03:53   #901  |  Link
NeverExists
It always says no hdr10+ present no matter what...... just let it load past that part. it has always said that for me right when I first load the preset, then after it loads the main menu... you said your file was HDR10 hence why it says no HDR10+ PRESENT.
NeverExists is offline   Reply With Quote
Old 18th March 2024, 03:57   #902  |  Link
NeverExists
Originally Posted by zomorf View Post
Can someone please point me in a direction. I'm trying a file that is HDR tv show with drag and drop to HYBRID script but pressing enter it reports no HDR HDR10+ detected... I had this working and now no files HDR is being detected... All I have done is extracted the new versions and all of a sudden it stopped... I had the Hybrid script working and found it a nice setup compared to the old extract and inject method...
I'm a novice to say the least...
IT is supposed to say that everytime you first load it. it will say that everytime there is no HDR10+ Present. You said you file was HDR10 Not HDR10+ so its working fine. let it load past that to the main screen.
Old 18th March 2024, 21:20   #903  |  Link
zomorf
Nope juts keeps prompting... So it just doesn't detect it for some unknown reason... I'm working again tonight so limited time.. I'll revisit it Wednesday...
Thanks to all with info suggestions...
lata,
zomorf
zomorf is offline   Reply With Quote
Old 19th March 2024, 07:22   #904  |  Link
NeverExists
Also make sure you select the video file first when you're loading it in the program cause if you click on the rpu file first, it won't recognize it.
Old 20th March 2024, 02:49   #905  |  Link
zomorf
I'm dragging an mkv file with HDR onto the Hybrid script. So I dont have the RPU file of the old extract and inject method.
I'll try a few more things later today when I get to the PC.
Once again thanks.
lata,
zomorf
Old 20th March 2024, 11:40   #906  |  Link
zomorf
OK solved... I'm sure before you could drag a file onto the SCRIPT name before and it would load... I was doing this... in versions 0.53 ???
NOW loading/running the HYBRID script and then dragging the file into the window solved the problem...
Sorry for the frustration but finally got it sorted... just when I was dragging the file onto the HYBRID script in file explorer etc it loaded the filename and I pressed enter presuming it knew the filename...
Dumb questions over and out Happily making Hybrids again...
lata,
zomorf
Old 24th March 2024, 17:25   #907  |  Link
cool advertise
cool advertise's Avatar
to -QfG-
I would like to point out, that the DDVT_MKVTOMP4.cmd script of your tool, when converting an mkv file that has chapters, to mp4, loses the chapters (discard chapters) in the conversion...
I had reported it on 6th February 2024, but received no reply.
Can you fix it?
cool advertise is offline   Reply With Quote
Old 31st March 2024, 20:23   #908  |  Link
AgentXXL
Version 2.1.1 of dovi_tool was released last week and it looks like it supports the AV1 codec. I personally don't use AV1 widely yet, but would be nice to do some comparisons with DV/HDR10+ injected HEVC. I might just try dropping the new version into the DDVT tools folder but not sure if it needs further refinement of the DDVT scripts.
AgentXXL is offline   Reply With Quote
Old 2nd April 2024, 05:05   #909  |  Link
TDS
Formally known as .......
TDS's Avatar
Maybe not...
https://forum.doom9.org/showthread.p...34#post1999834
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 27th April 2024, 09:32   #910  |  Link
anta777
Rx470 50VT50
It is possible to find out, having a release in the 8th profile, whether the rpu in it is real or obtained by converting these utilities from the 5th profile
anta777 is offline   Reply With Quote
Old 30th April 2024, 17:49   #911  |  Link
Atlantis
I just used version 0.63.1. You have removed the ability to output mkv in the Injector?
Atlantis is offline   Reply With Quote
Old 1st May 2024, 17:31   #912  |  Link
AgentXXL
You have to edit the script and set the options as per this post:
https://forum.doom9.org/showthread.p...44#post1997844
I was still doing it manually as well, but the new Hybrid script with drag and drop is working extremely well so I never use the manual method anymore.
Old 13th May 2024, 09:51   #913  |  Link
frandan
Good morning,
i began to use DDVT Tool for dovi rip a few months ago, but for the first time i saw in mediainfo report the voice "no metadata compression" as you can see in the following text
"HDR format                  : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible"
What does it mean? Did i make some mistake?
Thanks in advance for your answer
frandan is offline   Reply With Quote
Old 13th May 2024, 18:05   #914  |  Link
von Suppé
von Suppé's Avatar
No, I don't think you made a mistake. This seems a default note stating that the RPU binaries in the SEI messaging aren't further compressed.
I don't think I've ever seen otherwise. Just ignore it, things are OK.
Old 21st May 2024, 22:44   #915  |  Link
matey
Originally Posted by Fuso View Post
The other not-so-official way to change the Codec ID is to use HxD to edit the converted mp4.
Open the mp4 in HxD, use the Find (Ctrl+F) function and search for hev1 as a Text-string, then simply write dvhe over hev1 and Save the file.
hi @Fuso
have you figured out a way to convert mkv DV files so they work on older & newer LG tv's? I have a C8 & a A2. currently I am converting to m2ts using tsmuxer but that only works for the C8. I am not able to use dovi tools as my pc is a linux ubuntu arm64 so I haven't found a way to convert to a format compatible with both tvs.
matey is offline   Reply With Quote
Old 22nd May 2024, 06:18   #916  |  Link
TDS
TDS's Avatar
Originally Posted by matey View Post
hi @Fuso
I have an older LG TV, and the only way I could play a DV was to convert with tsmuxer, but the "seeking" during playback was horrible.
But then I found an app that was my "Saviour", and it's not DDVT.
The DV's also have to .mp4 to play on an LG TV, or some other device would be needed.
But most of these apps are Windows based, so I think you might have maybe dual boot your PC, so you can keep your Linux, and have Windows to do this stuff.
Or get a 2nd PC.
Old 22nd May 2024, 11:25   #917  |  Link
matey
Or get a 2nd PC.
hi @TDS
I have a windows pc too. can you please let me know which app you are referring to? is this for converting or playback? does it work for old & new LG tv's?
Old 22nd May 2024, 11:29   #918  |  Link
TDS
TDS's Avatar
hi @TDS
Happy to help...
I will send you a PM shortly.
Old 22nd May 2024, 22:12   #919  |  Link
Fuso
hi @Fuso
I'm currently mux them to Profile 5 with Base HDR/HDR10+, with Codec ID hev1. For many people is not "the way", but for me it does the job for my tv sets.
But I think I've found a universal format for playing on a non-DV TVs, older LGs, newer LGs - the so called fake Profile 5
HDR format                  : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                    : hev1
Container is mp4.
This file plays in HDR on a Samsung JS8000 (2015), AU9072 (2021), in Dolby Vision on LG B8 and C2.
Fuso is offline   Reply With Quote
Old 14th June 2024, 07:30   #920  |  Link
vitaloque
Small feature request. Add an option 'Use DV border' option to Hybrid script. It is often detetmined small border difference HDR vs DV RPU, and I have to manullay correct active area to match RPU. And for TV series it surely takes too much time.
So I'd like to press some number and output borders are automatically set to the one from RPU.
Thanks in advance.
vitaloque is offline   Reply With Quote
