Old 28th October 2023, 16:58   #781  |  Link
rco133
Originally Posted by von Suppé View Post
I'm getting confused about MediaInfo here.
Would someone please confirm me either right or wrong in thinking MediaInfo only shows Dolby Vision when in-container, and not in elementary stream? For DoVi, I've always presumed it relied on metadata written on container-level.
Mediainfo will not show any DV info until you have muxed the BL+RPU file into a mkv file.
At least that is what it does here.
rco133 is offline   Reply With Quote
Old 28th October 2023, 18:55   #782  |  Link
von Suppé
von Suppé's Avatar
My presumption was correct then. Thanks for confirming, rco133.
Old 30th October 2023, 00:04   #783  |  Link
SquallMX
Special SeeD
Is there a way to convert DV level 8.1 to level 7 for Blu-ray?
DDVT Tool can convert DV 8 to 7, but after that what should I do to create a compliant UHD Blu-ray disc with a MEL DV?
SquallMX is offline   Reply With Quote
Old 30th October 2023, 17:19   #784  |  Link
Atlantis
Is it possible to set the default output to mkv in Injector? I want to avoid to change it every time.
Atlantis is offline   Reply With Quote
Old 31st October 2023, 10:44   #785  |  Link
dkangel
You can change paths with DDVT_OPTIONS.cmd
dkangel is offline   Reply With Quote
Old 31st October 2023, 16:45   #786  |  Link
Atlantis
What about output?
Old 1st November 2023, 11:16   #787  |  Link
dkangel
it's the TARGET path
Old 1st November 2023, 11:55   #788  |  Link
von Suppé
von Suppé's Avatar
Originally Posted by GodzilaAvenger View Post
DoViBaker adds the EL information into the BL, essentially turning P7 into P8 without fully discarding the EL. At least that's what I think it does based on its GitHub repo.
Hope you don't mind putting this up here, -QfG-
I'm now doing a short test video with dovibaker. Where I understand the avisynth script takes not only video from BL and FEL, but also processes RPU and merge all in one videostream. Do some of you guys already have experience with recoding this? I'm using StaxRip. The avs script seems to play correct but video encoding errors out. I already asked at the StaxRip thread, but up to now haven't received answer so I'll put the screenshots here too. If somebody can see what I'm doing wrong, please tell me.
avs script:
LoadPlugin("F:\dovibaker\DoViBaker_x64.dll")
LoadPlugin("F:\dovibaker\DGDecodeNV.dll")
bl = DGSource("F:\dovibaker\BL.dgi")
el = DGSource("F:\dovibaker\EL.dgi")
SetFilterMTMode("DoViBaker",2)
DoViBaker(bl, el, rpu= "F:\dovibaker\RPU.bin")
ConvertToYUV420(matrix="2020")
ConvertBits(10)
Prefetch(8)
StaxRip error:
Old 1st November 2023, 19:06   #789  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Just guessing... CPU cap/build mismatch ?
I would try a different x265 build.
Old 2nd November 2023, 06:31   #790  |  Link
von Suppé
von Suppé's Avatar
Took the one from MeGUI. Encoding as I speak. Have to wait for outrcome, but so far so good.
Emulgator
Old 5th November 2023, 18:04   #791  |  Link
DiscoD
Is there an extra process to convert hdr10+ to DV?
Never seems to work for me using the demuxer.
DiscoD is offline   Reply With Quote
Old 6th November 2023, 03:28   #792  |  Link
Mark_Venture
Sorry, I'm a little late here, so I have a question I'm hoping someone would be kind enough to help with.
I have some videos that show:
ID/String                        : 1
Format/String                    : HEVC
Format/Info                      : High Efficiency Video Coding
Format_Profile                   : Main 10@L5.1@Main
HDR_Format/String                : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible
CodecID                          : hvc1
CodecID/Info                     : High Efficiency Video Coding
My understanding is that this file should fall back to HDR10 IF the player or TV doesn't support DV. Is that correct?
When playing on my Roku R4670 or my FireTV 4K Max or Roku R4800 on a Sony Non-DV TV using Plex or Kodi (kodi on the firetv only of course), it seems the "fallback" isn't working as I get a greenish tint.
Files like this play fine:
Format                                   : HEVC
Format profile                           : Main 10@L5@Main
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hvc1
Codec ID/Info                            : High Efficiency Video Coding
My understanding (from elsewhere) is that this file is HDR10. Someone also suggested this file might also fall back to SDR if the player doesn't support HDR, but I don't know if that is true.
Am I reading this thread correctly that all I should need to do with the files in the first format, is drop the MP4 files onto the DDVT_REMOVER.cmd set Remove Dolby Vision Meta = Yes, and start. Then the output will be like the second file and should look right?
Is that correct?
Mark_Venture is offline   Reply With Quote
Old 6th November 2023, 08:25   #793  |  Link
GodzilaAvenger
GodzilaAvenger's Avatar
DDVT_REMOVER removes the DV metadata, so yes, you should end up with an HDR10 file.
GodzilaAvenger is offline   Reply With Quote
Old 7th November 2023, 05:38   #794  |  Link
DiscoD
ID/String                        : 1
CodecID                          : hvc1
Format                                   : HEVC
Codec ID                                 : hvc1
Is that correct?
Make sure the devices are set to HDR only and not to any type of Dolby Vision Playback(LLDV,Automatic,etc) , I have those Roku's and my Files fallback to HDR fine with them. My files are MKV running through plex direct play but they always fallback to HDR.
Old 7th November 2023, 10:38   #795  |  Link
ivanb
Hey guys, just wanted to drop a quick note that the new VTCLab Media Analyzer (https://media-analyzer.pro) can now show RPU headers in HEVC streams. Could be handy in some cases.
ivanb is offline   Reply With Quote
Old 12th November 2023, 21:08   #796  |  Link
Grimm
Hello, I would like to ask you to add the option to set automatic start in the DDVT_OPTIONS file. Because when using demuxer and mkttomp4 I never change anything there anyway and pressing "S" becomes unnecessary
and I would like to ask you to add the option to set the default value for the mux stream in mkv yes/no item in the DDVT_OPTIONS file
Finally, I would like to ask you to add the option to create a file in the same directory as the source file without creating a separate folder. Because then you have to cut the rpu file and paste it into the source file for the injector to work, then when you convert it from mkv to mp4 it creates another folder again and that's how we get 2-3 additional folders....
In my opinion, the rpu file should be created right next to the source file so that you can immediately use the injector without having to deal with copying.
Grimm is offline   Reply With Quote
Old 23rd November 2023, 14:53   #797  |  Link
techdiver
Hi Guys,
I recently stumbled across this tool and started using it to great success. For the most part I just run DDVT_DEMUXER.cmd on my source file with DV Profile 7 and it extract it as Profile 8 and then I use DDVT_INJECTOR.cmd to combine the base and DV layer back in. Then I use MKVToolNix to combine back into mkv which works great.
I came across an issue I hadn't seen before last night whereby after the initial scan step of DDVT_INJECTOR.cmd I saw the following:
 == VIDEO INPUT =========================================================================================================
Filename   = [2001.A.Space.Odyssey.1968.2160p.BluRay.REMUX.HEVC.DV.HDR10.DTS-HD.MA.5.1.mkv]
Video Info = [Resolution = 3840x2160] [Codec = HEVC-10Bit-YUV-4:2:0] [Frames = 214088] [FPS = 23.976]
HDR Info   = [HDR, Dolby Vision Profile 7 Single Layer]
Borders    = [LEFT=0 px], [TOP=208 px], [RIGHT=0 px], [BOTTOM=208 px] [NOT MATCH WITH RPU]
 == RPU INPUT ===========================================================================================================
Filename   = [RPU.bin]
RPU Info   = [DV Profile = 8] [CM Version = 2.9] [Frames = 214088]
Borders    = [LEFT=0 px], [TOP=207 px], [RIGHT=0 px], [BOTTOM=207 px] [NOT MATCH WITH VIDEO]
Now I just let the process Start and everything worked fine, but I'm wondering whether I've produced a "bad" file at the end?
techdiver is offline   Reply With Quote
Old 24th November 2023, 07:13   #798  |  Link
GodzilaAvenger
It depends on the playback device, since some just discard the border values (L5 metadata, there is considerable conversation about it earlier in this thread which you can use the search tool to find). Also, the values are only off by 1 pixel so it won't be noticeable. It is also sometimes the case that ffmpeg outputs the wrong border values (the upper value).
Old 24th November 2023, 10:27   #799  |  Link
techdiver
Thanks very much for the reply. I'm playing them on android tv devices (nvidia shield, Sony OLED, etc).
I'll have a search back through the thread.
Old 25th November 2023, 09:11   #800  |  Link
von Suppé
von Suppé's Avatar
As @GodzilaAvenger said, there's not to much worry about 1 pixel difference. If the values shown at the videosection were to be correct, that is.
On the other hand, why not just change RPU's L5 values to the exact amount of pixels of video's black borders? This can be done with "EDIT ACTIVE AREA" in the INJECTOR script.
The black borders detection tool can drop a stitch. I always get video's exact border sizes by manually determining them from a (cherry-picked) screenshot in an image editor.
