Old 14th May 2023, 18:06   #541  |  Link
GodzilaAvenger
GodzilaAvenger's Avatar
With this custom.json file you are only applying the edits to the first 40 frames.
If the film's aspect ratio does not change you don't need a custom.json file, delete it and just use the INJECTOR script with the RPU and set the borders in the DDVT interface.
GodzilaAvenger is offline   Reply With Quote
Old 15th May 2023, 19:49   #542  |  Link
GHOSTWRiTAZ
GHOSTWRiTAZ's Avatar
Hi GodzilaAvenger,
Thank you for the swift reply.
Unfortunately I already tried that, the results are the same
Below the settings that I used:
Step 1:
Step 2:
Step 3:
Step 4:
Result remains the same 3840x1600 pixels (cropped/same as source without cinematic black bars/borders)
What I wish to achieve is 3840x2160 pixels (aspect ratio remains the same but cinematic black bars/borders are added during the DDVT Injector process)
Again any help on the matter is greatly appreciated. Thanks
GHOSTWRiTAZ is offline   Reply With Quote
Old 16th May 2023, 02:56   #543  |  Link
GodzilaAvenger
Ok, got it. DDVT can't letterbox a cropped .mkv file (add top and bottom black bars). It is only meant for handling dynamic metadata (Dolby Vision/HDR10+). If your .mkv file is 3840x1600, you should set the borders in the RPU to 0, as it originally was.
If you want to letterbox a video you need to use FFmpeg. For instance, see this and this on how to do it. If you do this and get a 3840x2160 .mkv, then you have to adjust the RPU borders as well (set top and bottom to 280).
Old 21st May 2023, 18:26   #544  |  Link
GHOSTWRiTAZ
Hi GodzilaAvenger,
I was under the assumption that it actually was possible, so I misunderstood/misread post #281 and #297
Meaning what I want to achieve is simply not possible without ffmpeg processing if the source is cropped 3840x1600 I will have to transcode it using ffmpeg filter to 3840x2160 pixels, which may result in loss of quality. Thanks for clarifying
Old 21st May 2023, 23:22   #545  |  Link
GodzilaAvenger
I highly doubt letterboxing using FFmpeg would result in loss of quality. Even if it did, the loss would be imperceptible.
Old 22nd May 2023, 06:48   #546  |  Link
TDS
Formally known as .......
TDS's Avatar
Is anyone here using x265 to inject the RPU's..
As the title suggests ???
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 22nd May 2023, 20:47   #547  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
-v0.54
*NEW New Script included (DDVT_Hybrid) for fast creating DV Profile 8.1 Hybrid Releases.
*INJECTOR-Function to change correctly the video framerate. Also included in HYBRID Script.
*Updated mkvtoolnix to v 76.0.0.0.
- SCRIPT <DDVT_HYBRID.cmd>
DESCRIPTION:
Simple quick script to create a DV Profile 8 Hybrid Release. Only add HDR
and DV File (No RAW file Support, only MKV/MP4 Container) set the options
and Go. Completely simplified and the fastest script to Build P 8.1 Files.
Also you can Input only a HDR10+ file without DV Input file and you create
a Profile 8.1 DV file based on the HDR10+ Metadata.
USAGE:
DDVT_HYBRID
-QfG- is offline   Reply With Quote
Old 24th May 2023, 04:39   #548  |  Link
TDS
TDS's Avatar
DV vs HDR10
I have just asked this question on the x265 thread
https://forum.doom9.org/showthread.p...16#post1987516
Does this make any sense to anyone here ??
Is there still and option to remove the HDR10 metadata ?? I could only see how to remove the DV metadata.
Old 24th May 2023, 09:39   #549  |  Link
von Suppé
von Suppé's Avatar
As TDS described in your linked thread, removing HDR metadata can render a device to not play the baselayer correctly. May I ask why you want to remove HDR metadata when video is HDR encoded?
Old 24th May 2023, 12:10   #550  |  Link
TDS
TDS's Avatar
TBH, I don't know if I need to be removing it, it's just that I am trying to figure out how to encode Dolby Vision, seems that most are Hybrid's.
Go here:- https://forum.doom9.org/showthread.p...77#post1987477 to see what I have been trying.
The difference between HDR Hybrid & and DV seems to be this :-
Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
and
Old 24th May 2023, 12:48   #551  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by TDS View Post
Is there still and option to remove the HDR10 metadata ?? I could only see how to remove the DV metadata...
If nothing else it would make an interesting addition for the completists!
SeeMoreDigital is online now   Reply With Quote
Old 24th May 2023, 18:08   #552  |  Link
dawid1991
hi how to convert dolby vision to hdr10+? i have a samsung and i would really need it?
dawid1991 is offline   Reply With Quote
Old 24th May 2023, 18:23   #553  |  Link
hidef_rec
hidef_rec's Avatar
Had asked that before; don't believe it's doable.
Thanks @-QfG- for the new version. Just tried DDVT_HYBRID, but when I drag-and-drop a HDR file (my sample is HDR10+ w/o DV) or any HDR file, nothing happens, it doesn't drop in. Am I doing something wrong?
Home Theater Fanatic
hidef_rec is offline   Reply With Quote
Old 24th May 2023, 19:25   #554  |  Link
GodzilaAvenger
and
Triggering DV also depends on the playback device and video container. For example if I remember correctly DV playback on an LG TV's internal media player using .mkv is not possible and it has to be .mp4.
Old 24th May 2023, 19:33   #555  |  Link
SeeMoreDigital
Correct. Although some people have had some level of success muxing Dolby Vision encoded content into .ts/.m2ts
Old 24th May 2023, 19:50   #556  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
You can not Remove "HDR Metadata" because they don't exist. HDR is a fixed included colorrange, you can remove only HDR10+ Metadata.
Old 24th May 2023, 19:53   #557  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
it looks so, that W11 don't support drag and drop I use W10 and have no problems with drag and drop. Will search for a solution.
Old 24th May 2023, 19:56   #558  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
There is no solution yet to doing this.
Old 24th May 2023, 21:40   #559  |  Link
dawid1991
Does anyone know if there is any bluray player 4k that plays 100gb r/rw discs?
Old 24th May 2023, 21:49   #560  |  Link
SeeMoreDigital
Out of interest...
Which 100GB (triple layer BDXL) 4K UHD disc movies do you have?
