Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 15th October 2021, 21:24   #1  |  Link
Perenista
Multi angle when the audio/subtitle streams are different
I was told in the past that I only needed to add (in MKVToolnix) different video angles and remove the same audio/subtitle tracks (if they were the same, of course).
However I noticed one of my movies actually has 4 angles and these 4 are using different audio and subtitle streams, despite the lenght being the same.
And it's a Blu-ray (1080p).
That means I need to use something else besides MakeMKV/MKVToolnix to do this job. The idea is not to have 4 separated MKVs, it's to combine all 4 into one, but being able to switch between all these different choices:
- ANGLE #1:
VIDEO A
AUDIO A
SUBTITLE A
- ANGLE #2:
VIDEO B
AUDIO B
SUBTITLE B
- ANGLE #3:
VIDEO C
AUDIO C
SUBTITLE C
- ANGLE #4:
VIDEO D
AUDIO D
SUBTITLE D
>>>>>>>>>>>>> ALL OF THIS into: SINGLEFILE.mkv
As far as I can tell this is not possible with MKVs. Is it?
ChapterEditor is converting the angles into 4 different files as well.
How should I proceed?
Perenista is offline   Reply With Quote
Old 18th October 2021, 17:48   #2  |  Link
hubblec4
Matroska find' ich toll
chapterEditor(cE) can mux all Angles into one mkv! cE is extra desigend for such a job, because with MKVToolNix(MTX) you need a lot of manually editing. But at the end, cE prepares the settings for MTX "only".
Set the Blu-ray editing mode to Multi-Edition-MKV before you start.
But keep in mind MTX is not able to remove the duplicated frames from the audio streams. You can demux the audio streams with cE -> eac3to is used.
hubblec4 is offline   Reply With Quote
