Old 6th September 2020, 17:01   #21  |  Link
qyot27
qyot27's Avatar
Originally Posted by Reino View Post
From the top of my head... libx265 doesn't support high bit-depth, but apart from that everything is the same.
It's not that it can't, it's that you have to use -DENABLE_ASSEMBLY:bool=off to enable 10 and 12 bit on i686 (which also means encoding to those bit depths will be slow as molasses, but it can be done). Nothing to do with XP.
Old 6th September 2020, 17:37   #22  |  Link
Reino
Reino's Avatar
I know that libx265 supports high-bit-depth. I should've chosen my words more carefully. What I meant was: the libx265 that's part of my FFmpeg binary doesn't support high-bit-depth, because...
http://hg.videolan.org/x265/file/tip/source/CMakeLists.txt:
if(X64)
    # NOTE: We only officially support high-bit-depth compiles of x265
    # on 64bit architectures. [...]
endif(X64)
My hobby website
Reino is offline   Reply With Quote
Old 30th April 2021, 19:40   #23  |  Link
Reino
Reino's Avatar
I've just uploaded new binaries. That is, only a static build for FFmpeg so far.
Running configure (while trying to compile a shared build) went just fine, but not with make. This is the short log:
GEN     libavutil/libavutil.version
GEN     libswscale/libswscale.version
GEN     libswresample/libswresample.version
GEN     libpostproc/libpostproc.version
GEN     libavcodec/libavcodec.version
GEN     libavformat/libavformat.version
GEN     libavfilter/libavfilter.version
GEN     libavdevice/libavdevice.version
CC      libavdevice/alldevices.o
CC      libavdevice/avdevice.o
CC      libavdevice/dshow.o
CC      libavdevice/dshow_common.o
CC      libavdevice/dshow_crossbar.o
CC      libavdevice/dshow_enummediatypes.o
CC      libavdevice/dshow_enumpins.o
CC      libavdevice/dshow_filter.o
CC      libavdevice/dshow_pin.o
CC      libavdevice/gdigrab.o
CC      libavdevice/lavfi.o
CC      libavdevice/reverse.o
CC      libavdevice/sdl2.o
CC      libavdevice/utils.o
CC      libavdevice/vfwcap.o
WINDRES libavdevice/avdeviceres.o
/bin/sh: /cygdrive/[...]/cross_compilers/mingw-w64-i686/bin/i686-w64-mingw32-gcc -E -xc-header
-DRC_INVOKED -MMD -MF libavdevice/avdeviceres.d -MT libavdevice/avdeviceres.o: No such file or directory
/cygdrive/m/[...]/cross_compilers/mingw-w64-i686/bin/i686-w64-mingw32-windres: preprocessing failed.
make: *** [ffbuild/common.mak:93: libavdevice/avdeviceres.o] Error 1
If anyone knows what's going on and knows how to fix it, I'd really appreciate it.
About the static FFmpeg build; thanks to Stephen Douglas the x265 library is now multi-bit-depth:
ffmpeg.exe -hide_banner -h encoder=libx265
Encoder libx265 [libx265 H.265 / HEVC]:
    General capabilities: delay threads
    Threading capabilities: other
    Supported pixel formats: yuv420p yuvj420p yuv422p yuvj422p yuv444p yuvj444p gbrp
                             yuv420p10le yuv422p10le yuv444p10le gbrp10le yuv420p12le
                             yuv422p12le yuv444p12le gbrp12le gray gray10le gray12le
My hobby website
Old 1st May 2021, 03:51   #24  |  Link
patul
Perhaps windres.exe (part of binutils) was the problem, maybe you can try to use previous working version?
patul is offline   Reply With Quote
Old 1st May 2021, 05:46   #25  |  Link
manolito
manolito's Avatar
Thanks...
Works here without any issues.
Old 1st May 2021, 10:46   #26  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Thanks for the new build, hugely appreciated!
Old 2nd May 2021, 15:18   #27  |  Link
Reino
Reino's Avatar
Too late I noticed "windres error with binutils 2.36.1" and the suggested fix, because I had already started a complete re-run with binutils 2.35.2.
Anyway, going back to 2.35.x proved successful. Thanks.
I've just uploaded new ffmpeg binaries and removed the "old" static one.
My hobby website
Old 2nd May 2021, 16:00   #28  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Thanks!
Any plan for a new build of ffms2 as well?
(I'm not in a hurry, just saying. And by the way, thank you so much for keeping the project updated and XP compatible).
Old 2nd May 2021, 16:54   #29  |  Link
Reino
Reino's Avatar
Seeing there are no new commits since my last build, I wasn't about to.
My hobby website
Old 3rd May 2021, 13:12   #30  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Ah, right, so nothing changed, I see...
Well, that's fine then.
Old 20th May 2021, 17:09   #31  |  Link
manolito
manolito's Avatar
@Reino
could you have a look at this post:
https://forum.doom9.org/showthread.p...04#post1943204
Old 26th June 2021, 15:38   #32  |  Link
GMJCZP
GMJCZP's Avatar
I'm testing version 4.5 static and it doesn't have the -preme argument (Estimation of previous movement) than if you have another videohelp build, the 4.2 static. Did they remove -preme?
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 27th June 2021, 10:29   #33  |  Link
Reino
Reino's Avatar
I have no idea what you're talking about. Are you sure you posted in the right topic?
My hobby website
Old 27th June 2021, 14:43   #34  |  Link
GMJCZP
GMJCZP's Avatar
In my signature I have a script based on FFMpeg to encode files to DVD. I downloaded the latest version and noticed that the -preme argument does not recognize it, my doubt is that the folks at FFMpeg removed -preme from their compilations.
Reino, or could it be that when compiling you skipped -preme?
By law and justice!
GMJCZP's Arsenal
Old 27th June 2021, 15:10   #35  |  Link
lvqcl
https://git.ffmpeg.org/gitweb/ffmpeg...e2c4287#patch3
avcodec: Remove private options from AVCodecContext
-#if FF_API_PRIVATE_OPT
-    /** @deprecated use encoder private options instead */
-    attribute_deprecated
-    int pre_me;
-#endif
lvqcl is online now   Reply With Quote
Old 27th June 2021, 15:19   #36  |  Link
GMJCZP
GMJCZP's Avatar
-    int pre_me;
-#endif
Thanks, but I downloaded a version shared from Here and is present -preme.
By law and justice!
GMJCZP's Arsenal
Old 27th June 2021, 16:13   #37  |  Link
Reino
Reino's Avatar
Apart from a couple of patches to make ffmpeg WinXP compatible again, I haven't removed functionality. At least, not that I know of.
My hobby website
Old 27th June 2021, 19:52   #38  |  Link
GMJCZP
GMJCZP's Avatar
Don't worry Reino, I suspect that preme was removed due to optimizations in the same encoding. I did a quick test and did not notice practically any major difference, so an increase in speed has apparently been gained, I say apparently because this increase may also be due to general optimizations.
By law and justice!
GMJCZP's Arsenal
Old 29th June 2021, 09:56   #39  |  Link
nevcairiel
The option is still available in newer FFmpeg, it just changed its name - the global option was removed, and the codec-specific one for mpeg remains. So for this particular option, try "-mepre" instead
Old 29th June 2021, 14:26   #40  |  Link
GMJCZP
GMJCZP's Avatar
Thanks for the clarification, I have confirmed the information.
By law and justice!
GMJCZP's Arsenal
