Old 26th December 2019, 15:00   #1  |  Link
stax76
stax76's Avatar
Can Direct2D render YUV420P8?
I've recently migrated StaxRip to render using Direct2D, it still creates a script with ConvertToRGB though. I wonder if it's easy enough to render YUV420P8, YUV420P10 and other popular AviSynth/VapourSynth formats directly in hardware with high quality scaling and Windows 7 compatibility?
https://github.com/staxrip/staxrip/b...nderer.vb#L224
https://github.com/staxrip/staxrip/b...nderer.vb#L196
Old 26th December 2019, 20:12   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Have you checked this document?
https://docs.microsoft.com/en-us/win...nd-alpha-modes
(especially the section about "Supported YUV Formats")
Old 26th December 2019, 22:01   #3  |  Link
stax76
stax76's Avatar
I'll study this document, thank you.
Old 23rd January 2020, 01:53   #4  |  Link
stax76
stax76's Avatar
It seems Direct2D can only handle RGB, for my purpose it's good enough however.
Old 23rd September 2022, 14:12   #5  |  Link
Ascet
If I can express my opinion, you don't have to stop at Direct2D. If you're happy with it now, you'll soon need to learn Direct3D or maybe even Blender immediately. My friend proved to me by example that in today's reality, Blender is preferable to master and is easier to configure and administer than Direct3D. My friend can use 3d models from Nebula for his work and post his work there. Let Direct2D is a hardware-accelerated API for 2D graphics which provides high performance and high-quality display of 2D geometry and text. But what if you want to work with three-dimensional objects?
Ascet is offline   Reply With Quote
