Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 19th November 2016, 13:52   #1  |  Link
sk2316
How to skip "intro java" in blu ray
I play angel & demon blu ray file in pc but it freeze at 90% of intro java.Can i skip this by edit playlist or anything?
sk2316 is offline   Reply With Quote
Old 25th August 2017, 11:09   #2  |  Link
neil wilkes
neil wilkes's Avatar
What soft player are you using?
The trouble with a lot of the cheaper and free ones is that they simply don't get the whole BD-J thing and tend to skip the menus.
Another possibility is that the soft player does not cope well with the AACS.
The reason I think the above is because what you are showing in the grab looks to me like the loading screen and not the actual BDJO First Play/Top Menu item - these are usually the same BDJO object when the disc is authored.
www.opusproductions.com
Multichannel Audio Productions
DVD-Audio/Video Authoring specialists
neil wilkes is offline   Reply With Quote
