Old 3rd January 2016, 11:03   #1  |  Link
ACrowley
x264 with --bluray-compat Ref Frames
Hi
i made a few Encodes with x264 and --bluray-compat Setting.
I know it overrides the X264 Settings to follow Bluray Specs.
I usally set Ref Frames to --ref 4 for Level 4.1 Compliant 1920x1080 encodes but x264 outputs always 3 with Bluray Compatible ?
Simple x264 cmd :
--level 4.1 --bluray-compat --preset veryslow --open-gop --ref 4 --slices 4 --vbv-bufsize 30000 --vbv-maxrate 40000
I hope somebody can clafiry this x264 behaviour
Greetings
ACrowley is offline   Reply With Quote
Old 3rd January 2016, 12:49   #2  |  Link
jpsdr
If i remember properly, there is something about the ref frame reduced by 1 (or something similar) when pyramid is enabled, which is the default setting. BTW, if bluray-compat doesn't change the pyramid setting (i don't remember if it does), it should pe put on "strict".
Old 3rd January 2016, 14:39   #3  |  Link
ACrowley
Thanks !
I found it :
B-Pyramid "Normal" = not reducing Ref Frames
B-Pyramid "Strict" = 1 reduced Ref Frame ,
--bluray-compat overrides to Strict
Old 13th January 2016, 17:52   #4  |  Link
benwaggoner
However, doesn't the Blu-ray spec require Strict?
Ben Waggoner
My Compression Book
Old 13th January 2016, 19:33   #5  |  Link
sneaker_ger
BluRay only allows "strict" or no b-pyramid, but like ACrowley said: --bluray-compat will (silently) enforce that.
Old 15th January 2016, 19:12   #6  |  Link
benwaggoner
The whole definition of "number of reference frames" is a little too ambiguous . I believe there are still actually 4 reference frames max in the decoded picture buffer with BD, but one is a "different" kind from the x264 perspective.
Ben Waggoner
My Compression Book
Old 5th March 2024, 16:33   #7  |  Link
wyup
Apart from vbv-maxrate=40000 and vbv-bufsize=30000, what is the max overall bitrate supported for a blu-ray?
It is an additional setting of x264: -B, --bitrate <integer> on Ratecontrol.
wyup is offline   Reply With Quote
Old 6th March 2024, 05:04   #8  |  Link
benwaggoner
The maxrate and bufsize define the max overall bitrate. The --bitrate parameter defines the mean bitrate, and --crf is often used instead.
Ben Waggoner
My Compression Book
Old 11th April 2024, 09:23   #9  |  Link
blob2500
Originally Posted by ACrowley View Post
Thanks !
I found it :
Some time ago I had done some tests to better understand what was meant by "strict".
IbBbPbBbP....
With this option active (B-pyramid "Strict"), it turned out to me that B-frames cannot refer to other B-frames, but only to P-Frames (and I). And of course, much less P-Frames cannot refer to B-Frames, but I and P only. But the "strict" option alone does not limit the number of frames to refer to 1.
The hierarchy is rigorous: I --> P --> B --> b
with "normal": I --> P/B <--> B --> b
blob2500 is offline   Reply With Quote
Old 11th April 2024, 17:41   #10  |  Link
jpsdr
It means it reduces the ref frame value of 1. If you've set 4 ref frame, it's reduced to 3.
My github.
