Old 10th October 2015, 02:37   #21  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
In coding, strip means "remove debug information." Even without specifically building debug, some debug information is embedded unless you strip it, so it's a part of most *nix builds.
Old 10th October 2015, 15:37   #22  |  Link
jpsdr
Ok, thanks for the remarks and informations, i've updated the tutorial.
Old 16th October 2015, 21:58   #23  |  Link
komisar
komisar's Avatar
For latest git FFMS2 and non-POSIX gcc threaing model need this patch
and `#if defined(_MSC_VER)` also need in ffms.h
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 20th October 2015, 17:36   #24  |  Link
jpsdr
What are the advantages of a non-POSIX gcc threading model ? (If any...)
Old 20th October 2015, 18:52   #25  |  Link
komisar
komisar's Avatar
In this case, ffms2 use threading for read number of CPU/working-threads... But when gcc compile without POSIX threading model on windows, this dont work. (You may make you app with POSIX thread, but gcc itself, and std::thread in c++11, dont)
As i understand guys use this for "unification" for C++11... But use this only for read number of CPU and break compatibilities with some compilers... This is a small/big question...
Old 21st October 2015, 09:07   #26  |  Link
jpsdr
Your patch is not working with the standard actual version of ffms2, one reason is that the make files are not in the same directory than in your patch.
Old 21st October 2015, 11:38   #27  |  Link
komisar
komisar's Avatar
`patch -p1 <"no_c++11_threads.diff"` work for me with current git
Old 21st October 2015, 12:25   #28  |  Link
jpsdr
I'll check again...
Ok, my mistake. I was mislead by tortoisegit which didn't display the red "!" on the make files after applying the patch.
Strange...
Old 18th January 2016, 16:46   #29  |  Link
jpsdr
Update x264 build script after r2664.
Edit : Update also of ffmpeg build script.
Old 1st April 2016, 12:53   #30  |  Link
jpsdr
Update of msys2 part since the last pacman update changes a little the process.
Old 30th May 2016, 09:38   #31  |  Link
jpsdr
Update the install link of msys2. I ask again moderators if this can be sticked, because i think it's interesting enough to be. If not, at least can you tell me why, or what is missing or need to be done to be sticked ?
Old 9th August 2016, 11:33   #32  |  Link
shekh
Can you explain how to invoke sh from windows shell? I tried passing it to sh.exe but got some shit.
Mingw tutorials just say "run configure as usual"..
VirtualDub2
Old 9th August 2016, 22:51   #33  |  Link
jpsdr
Oops. Deleted wrong message. I'm using msys2 shell, not windows shell, as i've explained in the tutorial.
Old 10th August 2016, 09:59   #34  |  Link
shekh
This works for me now (I had a stupid mistake in path command)
IMO much better than having to type commands in msys shell
@set msys=E:\work\ffmpeg_build\msys64
@set bin=%msys%\mingw32\bin
@path %path%;%bin%;%msys%\usr\bin
@set dir=%CD%
@cd E:\work\ffmpeg_build\build\x264-git\build-32bit
@sh ../configure --host=i686-w64-mingw32 --prefix=/local32 --enable-static --disable-cli
@make >%dir%\buildlib.log
@cd %dir%
VirtualDub2
Old 10th August 2016, 15:15   #35  |  Link
jpsdr
Still not working for me with gcc 6.1.0, but only on 64 bit builds, works fine on 32 bit builds.
I must say i had no idea what magical compile command option to add. In the other thread i've put the config log result, if any expert can take a look and tell me why what was working for gcc 5.3.0 is not working anymore for gcc 6.1.0.
Old 4th March 2023, 16:40   #36  |  Link
ghostshadow
hello @jpsdr I have an error using your script for ffm2:
$ ./Build_ffms2_x264.sh 64 posix jpsdr
./Build_ffms2_x264.sh: line 29: ../configure: No such file or directory
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target 'install'. Stop.
make: *** No rule to make target 'clean'. Stop.
I can't find the error.
thank
ghostshadow is offline   Reply With Quote
Old 6th March 2023, 18:32   #37  |  Link
jpsdr
OOOOOhhhh... A looot of things in this thread are obsolete.
I didn't maintain as was never able to make the admin stick it, and never had a reply of what is the process for asking to stick. As admin didn't care and were not interested in this, so do i.
Anyway, your issue is that there is no configure script anymore in ffms2. So copy autogen.sh, rename it autogen2.sh for exemple, delete the last line with configure and run the new version. It will create the configure file, and things will work again.
My github.
Old 9th March 2023, 19:05   #38  |  Link
ghostshadow
thanks @jpsdr
I managed to get my codecs.
Old 5th March 2024, 22:39   #39  |  Link
Yes thanx jpsdr, will be handy when I ever eventually try to compile a version of x264.
Methinks any guide to compiling a major open-source video related tool should be stickied, if only so people can find it.
Old 6th March 2024, 19:47   #40  |  Link
jpsdr
As i've said, a loooooooooooooot of things have changed, and probably at least 50% should be re-written.
More... Now ffms2 changed the api, needing at least ffmpeg5, but to be able to use some patches wich are ooold, you can't go over ffmpeg4.
So, i had to create a specific branch of ffms2 just before the changes needing ffmpeg5 were commited. Meaning ffms2 is not frozen (at least in my releases).
The best for these patches would be to still being able to use ffmpeg2, but x264 needs at least ffmpeg3 i think.
My github.
