Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 26th August 2015, 18:42   #1  |  Link
jmsmarcelo
jmsmarcelo's Avatar
Erro in Disc Info Scenarist BD [Solved]
Please help,
Warning : The size of layer0 may be larger than the max layer size. (Size: 453,121,892,825bytes, MaxSize: 25,025,314,816bytes)
Layer0 (18%) used.
Video Size: 3,987,439,852 bits, Time: 00:26:35:08, Bit Rate: 34,999,296bps, Frame Rate: 23.976fps, Format: MPEG-4 AVC
encoded with Cinevision:
Bite Rate:
Base Target: 20.00 Mbps, Base Maximum: 35.00 Mbps, Maximum Quantization: 70%
JMSPreviews
Previews of:
Authoring DVD/Blu-ray with Scenarist
Creating Subtitles for Scenarist SD/Scenarist BD
Adding chapters in Scenarist SD/Scenarist BD
and so on...
jmsmarcelo is offline   Reply With Quote
Old 27th August 2015, 19:48   #2  |  Link
Alex-Kid
Antronio's DV ambassador
Alex-Kid's Avatar
It happened the same to me, but then I realized Scenarist was wrong, because it shows the resulting files are about 100 times bigger! Percentage (18%) shows the correct space used.
Continue MUX though warnings were detected? CONTINUE.
This way I got a BD with no errors.
Alex-Kid is offline   Reply With Quote
Old 28th August 2015, 00:43   #3  |  Link
jmsmarcelo
jmsmarcelo's Avatar
I managed to fix the bug
Open Regedit: HKEY_CURRENT_USER\SOFTWARE\Scenarist\Scenarist BD
Edit MuxStreamSizeCoef: 1,06 to 1
Or uses this patch to fix bug
File Type: zip Layout_Editor_Fix_Size.zip (338 Bytes, 242 views)
Old 28th August 2015, 14:20   #4  |  Link
Alex-Kid
Alex-Kid's Avatar
Thanks for this fix!
Old 25th August 2017, 11:14   #5  |  Link
neil wilkes
neil wilkes's Avatar
That's a weird bug.
What build of Scenarist BD is it found in, please?
(I ask only because I have not as yet seen it in 5.3.2 or 5.7, and am not sure if my copy needs to be patched and I have not yet renewed my support deal with Scenarist LLC)
www.opusproductions.com
Multichannel Audio Productions
DVD-Audio/Video Authoring specialists
neil wilkes is offline   Reply With Quote
Old 28th August 2017, 12:49   #6  |  Link
jmsmarcelo
jmsmarcelo's Avatar
Originally Posted by neil wilkes View Post
That's a weird bug.
Hello, This bug does not affect the project, it only returns wrong information of the final project size in Disc Info. This error appeared in version 6.0, and fixed in v6.1.2.
Old 29th August 2017, 09:02   #7  |  Link
neil wilkes
Ah - that explains why I have not seen it - not (yet) updated to this build (although I will be in October once this years big workload is done)
