Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 19th April 2015, 12:51   #1  |  Link
minhjirachi
Self sign JAR file
Close topic!
minhjirachi is offline   Reply With Quote
Old 29th July 2015, 06:08   #2  |  Link
andresayang
Originally Posted by minhjirachi View Post
I want to re-sign the jar files with my pair keys. But how to generate the pair keys to sign them? And how to convert to .crt file?
Thank you.
Do you know hdcookbook ?
In this free project you will find everything you need for this.
Otherwise you need to use Scenarist Safegard.
andresayang is offline   Reply With Quote
Old 25th August 2017, 11:16   #3  |  Link
neil wilkes
neil wilkes's Avatar
2 problems here.
1 - HD Cookbook website is dead - taken down & gone.
2 - Safeguard in Scenarist BD 5.3.2 & 5.7 running under Windows 7 both have a nasty bug and it is impossible to actually create the key pair in the first place. You can go through all the steps but every time you get to the point where you hit "Create" - nothing happens!!
Apparently it is fixed in the latest version 6.1x but I will not know for sure until I update in October.
www.opusproductions.com
Multichannel Audio Productions
DVD-Audio/Video Authoring specialists
neil wilkes is offline   Reply With Quote
