Old 1st February 2012, 18:54   #1  |  Link
Dmitry Vergheles
Dmitry Vergheles's Avatar
H264/AVC frame accurate editing (AVCHD/MOV/MP4/MKV) of SolveigMM
Hi Guys, we've just released SolveigMM Video Splitter 3 with support of frame acuracy editing of h264 video (in addition to MPEG-2 and Windows Media)
http://www.solveigmm.com/en/products/video-splitter/
It would be grate to have a feedback / suggestions or bug reports.
- New and improved interface
- MOV/MKV/MP4/AVCHD formats frame accurate trimming and joining
- Thumbnails on timeline feature
- Time format switching (time and frame\ time)
- Now it is possible to set markers within a frame (it is useful in case one frame is too long - 1 minute or so)
We'll post here a demo key shortly.
Regards,
Dmitry Vergeles
Solveig Multimedia - Video Editing Software
Dmitry Vergheles is offline   Reply With Quote
Old 2nd February 2012, 00:53   #2  |  Link
CruNcher
CruNcher's Avatar
Interface:
I like the interface the storyboard is nice, and you find fast your way without reading the manual how to use it getting the idea of fragments (the batch functionality) and the slider, markers very nicely layed out (also the time zoom function) very different to what all the Chinese All in one Converter Studios and Splitters do
Also from a Design Point it looks more Windows like then in comparison Avidemux QTs framework (though that says nothing about efficiency,robustness and quality) or i guess you could also make the compare with VideoRedos Interface which isn't so nice (also 1 very big plus you don't brake the editing flow with different editing modes but allow anything in 1 task)
So for the Interface a clear 1
Engine (Dshow based):
As expected to reach frame accuracy it uses Smart Rencode with Elecards H.264 Encoder hehe i missed that Elecard logo though you have overwrite capabilities of decoder and encoder decisions it seems this makes it also very unique as the Preview can be accelerated either via DXVA native/copy back or Quicksync
The Preview of H.264 is by default done with the Elecard Decoder, parser/muxer <- (here most of the issues will come from) in the backend are all Solveigs own ones as expected
VideoRedo Smart Reencode = Mainconcept
SolveigMM Smart Reencode = Elecard
PS: Dimtry your Introduction Video cant bee seen here in Germany (its blocked) as the GEMA didn't bought the rights for the Music used in it in Germany (YoutubeID @ least marks it as such)
It is about Time
Old 2nd February 2012, 10:23   #3  |  Link
Ulf
SolveigMM Video Splitter craches for any file I throw at it with the error message:
Problem signature:
Problem Event Name: BEX
Application Name: SMMVSplitter.exe
Application Version: 3.0.1201.27
Application Timestamp: 4f222e9e
Fault Module Name: StackHash_0a9e
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 00000000
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1053
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
I am running Windows 7 x64. I have tried different compatibility modes and turned off Data Execution Prevention. Nothing seems to help. Any idea?
Ulf is offline   Reply With Quote
Old 2nd February 2012, 11:39   #4  |  Link
smok3
brontosaurusrex
smok3's Avatar
.works here (win7 64), seems to do the job.
.There seems to be some Elecard logo issues.
.The editing gui is (at least) two pane (player, recorder) and nothing will change that, not even fcp x.
.The colors in gui should be really pale (if unsure what that means: don't use colors), video must stay in center focus all the time.
professional illustration:
| play         |  | rec          |
buttons           buttons
timeline |      |   |  |       |
certain other member
smok3 is offline   Reply With Quote
Old 2nd February 2012, 12:36   #5  |  Link
Stanislav Mikhailenko
Stanislav Mikhailenko's Avatar
Ulf, could you make log files to determine the problem?
Use this instruction: How can I record log files
Stanislav Mikhailenko is offline   Reply With Quote
Old 2nd February 2012, 14:03   #6  |  Link
Dmitry Vergheles
Originally Posted by CruNcher View Post
Interface:
Hi Cruncher,
Thank you for good opinion. To make a right stoybord was a really challenge
BTW - didn't know that Redo uses MC.
>>that Elecard logo
Tha's not a bug, that's restrictions of evaluation version. After registration - no logos, neither in preview nor in transcoded parts.
Not for all AVC formats
Yeah, I know, I also can't watch it.
We are changing audio layout there.
Regards,
Dmitry Vergeles
Old 2nd February 2012, 14:07   #7  |  Link
Dmitry Vergheles
| play         |  | rec          |
buttons           buttons
timeline |      |   |  |       |
Hi smok3,
Thanks. Logos is trial restrictions.
Could please you explain this point in more detail?
Well, may be it makes sense to add some color sets.
Regards,
Dmitry Vergeles
Old 3rd February 2012, 00:22   #8  |  Link
Ulf
No need. I found the problem. After uninstalling MysticThumbs it works. MysticThumbs is a software that generates thumbnails of many image formats not natively supported by Windows. Seems to interfere with SolveigMM Video Splitter 3.
Correction:
It had noting to with MysticThumbs - just a coincidence that SolveigMM worked after uninstalling MysticThumbs. I have a system with an Optimus NVIDIA hybrid graphics card. In the NVIDIA Control Panel I set the preferred graphics processor to "Integrated graphics" and SolveigMM works again. I did the same for Subtitle Workshop and finally I got the movie preview window to work.
Old 3rd February 2012, 08:49   #9  |  Link
smok3
brontosaurusrex
smok3's Avatar
Editing is always partially picture comparison and single window editor will mostly make that more difficult (even something that may be seen as strictly technical goes into the same basket imho).
One could improve on that with some simple addons as well : "view X-comp" and "EE" buttons on the record side.
X-comp - shows 50:50 recorder and player frame for the time that button is pressed.
EE - shows player frame in record window for the time that button is pressed (fast switching must be possible). That is old fashioned tape to tape standard.
(I'am amazed there is no nle that would offer this two)
Old 3rd February 2012, 10:05   #10  |  Link
Ghitulescu
Ghitulescu's Avatar
When one picks the START/END frames, are they included in the cut or not?
Smart rendering occurs up to I-frames or IDR-frames (important for DVB-S2 streams, and why not, for older PCs)?
Are all streams (say TXT, DVB-subtitles) kept and processed?
What about variable delays, so often found in SAT recordings (main features has an audio delay, the commercials another), are they accounted for?
Sorry for these questions, I know that I can download the trial and do myself this, but I don't install trials PER DEFINITION on my working PC.
Born in the USB (not USA)
Old 3rd February 2012, 12:41   #11  |  Link
andybkma
Found a bug: When typing in the end time of the scene that you want to split, on the right counter if you type in the number 3 and anything above 3 (4, 5, 6 etc) for milliseconds (example: 00:11:26;30) it causes the whole timer to jump up one second (so if I type in the previous example, the timer jumps to 00:11:27;00 instead of staying at 00:11:26;30). However if you type in the number for 1 or 2 for the milliseconds it works (00:11:27;20). So this must be a bug as I am not able to accurately put in the end split time I want into the timer. This happened with any video format.
andybkma is offline   Reply With Quote
Old 4th February 2012, 00:04   #12  |  Link
Dmitry Vergheles
Agree. But at the moment we don't alter picture, no effects appliable.
Regards,
Dmitry Vergeles
Old 4th February 2012, 00:05   #13  |  Link
Dmitry Vergheles
Hi Ghitulescu,
Should be included
Regards,
Dmitry Vergeles
Old 4th February 2012, 00:07   #14  |  Link
smok3
brontosaurusrex
smok3's Avatar
Dmitry Vergheles: schnitt is what iam talking about (nothing to do with effects). Sorry if this is getting totally off-topic...
Old 6th February 2012, 11:27   #15  |  Link
andybkma
Any comment on my bug report? Do you need any other information?
Old 6th February 2012, 21:54   #16  |  Link
Dmitry Vergheles
Hi Folks,
sorry for delayed answers.
andybkma, that's not a bug, because format is h:min:sec;frame, so the latest digits are frames.
You can also change it to h:min:sec,millisec, but then you'll see 3 digits in this field
Regards,
Dmitry Vergeles
Old 6th February 2012, 21:57   #17  |  Link
Dmitry Vergheles
Ok, I understand the idea that you need to preview somewhere a possible editing result before you start it's rendering. We'll do such a feature but probable in the same window, it is necessary to think about. But in any way, we are going to make version 4, with ability to work at the same timeline with multiple files (now only one file in timeline depicted).
Regards,
Dmitry Vergeles
Old 6th February 2012, 22:00   #18  |  Link
Dmitry Vergheles
Hi Ghitulescu,
Sorry also for delayed answer.
Should be included
Good question, actually IDR can be meet in an input stream very seldom, so at the cue-points we re-make IDR (something like that, can't tell you full details)
Not yet
Not yet, but in our to-do list.
If you want, we'll send you a key for evaluation.
Regards,
Dmitry Vergeles
Old 6th February 2012, 22:05   #19  |  Link
Dmitry Vergheles
Btw, there is a cool feature to set timeline in frame by frame mode
Regards,
Dmitry Vergeles
Old 6th February 2012, 22:23   #20  |  Link
Dmitry Vergheles
It seems at this stage it is easier to give evaluation keys. Please let me know who have an interest. We need name, surname, email and company (optional), can be sent to PM.
Regards,
Dmitry Vergeles
