Old 6th July 2011, 23:24   #61  |  Link
kieranrk
Originally Posted by kolak View Post
x264 at 100Mbit is great, but still not that easy to cope for NLE.
x264 decoding with sliced threads would probably be ok.
kieranrk is offline   Reply With Quote
Old 7th July 2011, 01:09   #62  |  Link
henryho_hk
Does XviD support interlaced encoding (MBAFF) ?
It supports Progressive, TFF and BFF. Easily selectable via xvid_encraw (multithread unfriendly) and VFW GUI (via Virtualdub which is multithread friendly, fully unleashing the new sliced-threading).
Note that the new sliced-threading may have compatibility problems with hardware standalone players, but there is no need to worry if used as an intermediate codec.
henryho_hk is offline   Reply With Quote
Old 7th July 2011, 05:48   #63  |  Link
Alex-Kid
Antronio's DV ambassador
Alex-Kid's Avatar
Originally Posted by henryho_hk View Post
xvid_encraw is not multithread-friendly at all.
I didn't note that, but now that you have mentioned, I don't remember any option related to multi-threading. Then I have to assume that MeGUI didn't have multithreading support either.
Table updated with results from henryho_hk (post). Just to keep things in order.
Alex-Kid is offline   Reply With Quote
Old 7th July 2011, 07:18   #64  |  Link
henryho_hk
xvid_encraw has "-threads" option (squid80's 1.2 version is better threaded) and the newer 1.3 versions has the "-slices" option. "-slices" should scale quite well but I find it much better realized in VirtualDub via VFW.
Concerning the speed, I suggest adjusting it by prorata as ~30.89fps = ~35fps / ~40 * 35.3
Old 7th July 2011, 10:10   #65  |  Link
kolak
Yes- for simple timelines it works fine, but once you make it more complicated (or use multicam) it starts showing problems.
It's still more difficult than all intermediate codecs.
For crucial work it needs 150Mbit or more, so that's make it even more difficult.
Andrew
Old 7th July 2011, 10:20   #66  |  Link
nm
Bad decoders and demuxers aside, I don't see a format-related issue that would make it more difficult as long as you only have intraframe video.
Old 7th July 2011, 11:01   #67  |  Link
kolak
It just complicity of AVC- all intermediate codecs are much easier to decode.
Edius export for this sample to HQX (about 120Mbit)= 145fps using 12 cores at 100% (all CPU processing).
There are different implementation of the decoders, but we're talking about using AVC as an intermediate format- so it has to work in NLEs.
In Edius to play this sample CPU=7%, for HQX file=4%.
Not sure how good is Edius AVC decoder, but I have not seen better NLE for handling AVC files.
Going to encode it to AVC-I using posted cmd and check playback.
AVC-I CPU=6%, but seeking is much better.
Andrew
Old 7th July 2011, 11:18   #68  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
@kolak
http://forum.doom9.org/showthread.ph...72#post1508272
Old 7th July 2011, 11:32   #69  |  Link
kolak
Decoding speed?
To have fast decoder is one thing, but to have it working inside NLE with timeline, seeking is another.
Andrew
Old 7th July 2011, 11:44   #70  |  Link
Atak_Snajpera
What is your problem if we are talking about AVC-INTRA (each frame is independent) in mp4 container?
Old 7th July 2011, 11:50   #71  |  Link
kolak
Yes- I know.
Not sure what are you talking about
I've encoded this sample to AVC-I using posted cmd line. I had 80fps using 60% of 12 cores. It may maxing my HDD speed.
update- it was maxing HDD- encodign from Canopus HQ gives about 180fps (6x faster than RT) and 70% of all 24threads. Should it be 100%?
Andrew
Old 7th July 2011, 11:51   #72  |  Link
Atak_Snajpera
Have you increased number of decoding and encoding threads?
Old 7th July 2011, 11:57   #73  |  Link
kolak
Encodign from uncompressed.
One note- people encode to AVC-I with x264, but this streams are way out of Panasonic AVC-I spec as far as I can see.
If it's just AVC with I frames only than fine, but it has nothing to do with AVC-I spec.
Andrew
Old 7th July 2011, 12:22   #74  |  Link
Atak_Snajpera
Are you sure that your hdd is not a bottleneck again? Increase number of encoding threads.
Old 7th July 2011, 12:24   #75  |  Link
nm
Maybe some people encode to AVC-I, but you are the only one who has mentioned it in this thread so far. There's no reason to care about Panasonic specs when the stream is used internally and the tools aren't limited to AVC-I.
Old 7th July 2011, 14:25   #76  |  Link
kolak
That's the whole point- you need compatibility with AVID and rest of Pro software if you want x264 being used commercially.
It should be also 4:2:2 as intermediate codec.
For home use you can do whatever you want. You never have good quality source- best is ripped BD, so it's bit pointless anyway.
Andrew
Old 7th July 2011, 14:29   #77  |  Link
Atak_Snajpera
Does so called pro software support mp4 container as input? BTW. I'm not "PRO" so for my AVCHD recordings x264 Intra 100 Mbps is perfect. Small size + very high quality + very fast decoding speed + natively decoded by Sony Vegas + it' free. Why should I use something else.
I always thought that x264 10 bit does that.
Old 7th July 2011, 14:31   #78  |  Link
kolak
No- it can do 450MB/sec. Canopus HQ file is about 150Mbit.
It can be related to decoding in avisynth (I read it through mt mode 2). I know that it works 2x as fast in Edius- decoding/encoding for HQ.
Andrew
Old 7th July 2011, 14:31   #79  |  Link
kolak
Depends which- some do. Most likely you need MXF.
Andrew
Old 7th July 2011, 14:39   #80  |  Link
kolak
Exactly, but world does not end only on your needs
Yes- but posted cmd line is for normal 8bit encoding. 10bit 4:2:2 would be even slower for decoding.
That's why I said that HQX is great- quality can be set from offiline to higher than HDCAM-SR and all extreamly fast for processing. Not free, but also not very expensive.
There is no specially designed, free intermediate codec (except DNxHD- but it's quite limited)- only paid ones. We have amazing lossless ones- like UtVideo, but someone would like lower bitrate (for small loss in quality).
Andrew
codec, hdtv, intermediate
