Old 9th May 2024, 19:04   #25241  |  Link
AngelGraves13
Will you be adding DirectX 12 copy-back mode support?
MPC-BE just added it, so I'm guessing it's not far behind for LAV.
From MPC-BE 1.7.0 notes
"Added support for D3D12 copy back mode"
AngelGraves13 is offline   Reply With Quote
Old 9th May 2024, 19:09   #25242  |  Link
nevcairiel
For Copy-Back in particular it doesn't seem to have major advantages. Why would you want to use it?
The only reason to support it would be if a video renderer use D3D12 and wants interoperability - eg. in Native mode.
Old 14th May 2024, 14:47   #25243  |  Link
max79
Support request - #41
@Nevcairiel
This SPEEX-audio file is played with distortion. Link for downloading:
https://dl.dropbox.com/scl/fi/596hxu...cpeyaiuy8i89tc
I'm noticed that I have no such issue when playing it on my PC through VLC.
Any feedback would be appreciated.
max79 is offline   Reply With Quote
Old 14th May 2024, 23:42   #25244  |  Link
AngelGraves13
There must be a benefit otherwise why would someone go to the trouble of programming it?
I'd be more interested in a DX12 "native" mode, to be completely honest.
Old 15th May 2024, 12:45   #25245  |  Link
maybe ask them.
there is even a lavfilter version with dx12 and a mpcVR that is DX12 if any of these are native is beyond me.
Old 15th May 2024, 17:43   #25246  |  Link
richardpl
Originally Posted by max79 View Post
@Nevcairiel
FFmpeg is dead, use Librempeg where this have been fixed ages ago.
richardpl is offline   Reply With Quote
Old 16th May 2024, 00:22   #25247  |  Link
nevcairiel
I named a reason why someone might want it. There is just no demand for that in LAV.
Video decoding is ultimately just an API to access the video decoding hardware. There is no huge difference what you use - so what it comes down to is what something else uses that wants decoding. If that uses D3D12, then you use a D3D12 decoder. That's all.
Noone has made an actual D3D12 video renderer, or approached me about supporting it for that. This is not a user-relevant feature, but would only benefit another video renderer that wants to run in D3D12.
As for a video renderer - if all you do is use simple shaders and using D3D Video Processing, there is no benefit in D3D12 anyway, you only get a lot extra complexity for no benefit. Only once you start using much more complex shaders, compute shaders in particular, would there be any benefit, as D3D12 gives you access to the newer shader models.
Old 16th May 2024, 09:02   #25248  |  Link
Brazil2
Where are Librempeg binaries downloads for Windows ?
Brazil2 is offline   Reply With Quote
Old 16th May 2024, 09:29   #25249  |  Link
Aleksoid1978
Aleksoid1978's Avatar
@Nevcairiel
Perfect play with ffmpeg + https://github.com/xiph/speex.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 16th May 2024, 11:28   #25250  |  Link
richardpl
Compile it!
Old 16th May 2024, 11:29   #25251  |  Link
richardpl
That library is highly under optimized, do not use.
Old 16th May 2024, 14:47   #25252  |  Link
Brazil2
Compile it!
Without any public download of libraries for Windows the use of Librempeg will be very marginal.
Old 16th May 2024, 17:16   #25253  |  Link
richardpl
Sure, keep using buggy software that is build by random guys.
Old 16th May 2024, 17:35   #25254  |  Link
max79
Алексей приветствую,
спасибо за отклик! Почему всё так сложно?
Есть ли возможность прикрутить то что ты посоветовал(или AviSynth+) к DirectShow плееру?
Old 16th May 2024, 17:48   #25255  |  Link
Brazil2
Compile it!
Compile it yourself and offer binaries to the world. If you don't then you will miss the vast majority of Windows users who also are the vast majority of computers users.
Old 16th May 2024, 22:07   #25256  |  Link
Aleksoid1978
Есть ли возможность прикрутить то что ты посоветовал(или avisynth+) к directshow плееру?
В mpc-be на встроенном декодере это уже и так прикручено. Можно взять его, а можно просто взять декодер, он доступен в виде внешнего фильтра.
Old 30th May 2024, 23:46   #25257  |  Link
clsid
@nevcairiel
Can you build a GCC 13.3 MinGW pack?
MPC-HC 2.3.0
Old 31st May 2024, 05:10   #25258  |  Link
Aleksoid1978
@nevcairiel
Why - there is already a gcc 14.1 release.
Old 4th June 2024, 13:25   #25259  |  Link
clsid
GCC 14.1 is fine too. In past I usually skipped .1 versions but I guess there is little reason for that nowadays.
And possibly another FFmpeg update for the addition of xHE-AAC decoder would be awesome as well.
MPC-HC 2.3.0
Old 4th June 2024, 13:29   #25260  |  Link
LigH
LigH's Avatar
The reason GNU starts with .1 releases today is that everyone started to skip .0 releases...
New German Gleitz board
